Wheel bearings and an "arbor press"? - JeepForum.com
post #1 of 4 Old 05-24-2003, 05:30 PM Thread Starter
nack
I'm new at the forum thing and automotive repair, so please bear with me. Thanks.
I have an 82 Scrambler that I am replacing the rear wheel bearings on; besides not being able to get the hubs off, the Chilton's manual claims I need an "arbor press" to change out the bearings. Is this true? What is an "arbor press"? And where do I get one? My mechanic friend has never heard of one, nor has anyone at autozone. Any thoughts?
T. Nackowicz
1982 Scrambler... almost
nack is offline
post #2 of 4 Old 05-24-2003, 05:48 PM
fuzz401
1978 CJ7
an arbor press is a hand operated press you pull on a handle to get the pressure
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 4 Old 05-25-2003, 04:23 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
SOP for Rear Wheel Bearing!
Cut off old bearings and press on new, arbor or otherwise.
I suppose if you had a piece of pipe a little larger than the ID of the bearing you could drive the bearing on but the press allows a more controlled install. Don't get the pipe too big so it hits the bearing area itself.
LOL,
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #4 of 4 Old 05-25-2003, 12:32 PM
knowlwk@snowhill.com
1980 CJ7
Do yourself a favor and drop bucks on 1-piece axles... no reason to take it all apart twice.
'80 CJ7, 258 W/Autojuicer, MC 2100, TFI, SummitRacing CDI, MORE SRS, Moser 1-pc, YJ tub on 1" body lift, YJ family cage.
knowlwk@snowhill.com is offline
How to Press Wheel Bearings on One Piece Axles Hybrid Jeep Jeep CJ Forum 18 01-09-2012 08:32 PM
Do you own an Arbor Press? 243 Jeep CJ Forum 12 12-02-2009 10:52 AM
How to position D300 in the Press to remove bearings? CJman77 Jeep CJ Forum 2 11-21-2009 07:55 PM
Auto Shift Linkage "bearings" ctm Jeep CJ Forum 2 11-17-2009 05:41 PM
Maximum wheel offset for a 15"x10" wheel on a CJ5? aqsport196 Jeep CJ Forum 6 04-01-2009 05:19 PM
