Wheel bearing? Ball joints? I need help?! - JeepForum.com
post #1 of 9 Old 12-23-2012, 04:35 PM Thread Starter
gunslinging81
1980 CJ7
Hey guys 1st post here. Guess I'll just get started. I'm having an issue with
some camber on my front tires on my 1980 cj7. I've been doing some
research and found that if you jack the front end up and try to shake the tire
from top to bottom it should not move, and if it does it's more than likely a
ball joint issue. However when i wobble the tire from top to bottom it looks
as if the ball joints arent the problem. This makes me believe its the
bearings in the wheel. My question is, being a novice mechanic, what is the
best way to get into the hub? wheel? to check and see if this is infact a
wheel bearing problem. I dont drive the jeep daily so I'd like to do this all
myself, I dont really care how difficult this would be. Also any pictures of
videos would be a tremendous help.
Thanks fellas,
Gunslingin
gunslinging81 is offline
post #2 of 9 Old 12-23-2012, 04:42 PM
deadeye
1983 CJ7
Try this http://www.jeepforum.com/forum/f8/ca...g-help-673545/
83 CJ7, 350 TBI, TH350, Dana 300 twin stick, Dana 44 E-locker, Ford 8.8, Detroit, 4:10 gears, 35x13.5x15s
"Just Exchange Every Part"
deadeye is offline
post #3 of 9 Old 12-23-2012, 04:43 PM
walkerhoundvm
1981 CJ8
I did a thread when I replaced my bearings, ball joints, and u joints, but this one is the one I used to do it:
Jeephammer's Dana 30 servicing thread
walkerhoundvm is offline
post #4 of 9 Old 12-23-2012, 04:44 PM
walkerhoundvm
1981 CJ8
missed it by that much...
post #5 of 9 Old 12-23-2012, 04:47 PM
walkerhoundvm
1981 CJ8
You want part numbers, sources, and prices, see here: My dana 30 rebuild thread
post #6 of 9 Old 12-23-2012, 04:52 PM Thread Starter
gunslinging81
1980 CJ7
wow that took about 5 minutes! haha think im gonna like this forum.
post #7 of 9 Old 12-23-2012, 06:37 PM
hp_lovecraft
1981 CJ5
The good news is that its not that expensive, or technical. Nearly all the parts are at your local parts store. (ie bearings, etc). You can rent the bearing set tool for free.
THe only thing you will have to order is the hub removal socket. Its a special Jeep tool you can only get at 4wd, quadratec, etc. The local places will not have it. Otherwise take everything off one at a time. Have a small container handy for all the small parts.
If your rotor is junk, you can change that as well. You need to remove the hub to change it, so its not a bad time, and those are pretty cheap as well. Its trickier then other cars, as the rotor sits behind the hub, pressed in by the wheel lugs. YOu need to hammer those out to get the rotor off.
hp_lovecraft is offline
post #8 of 9 Old 12-23-2012, 10:05 PM
jhedges15
1973 CJ5
When checking for bearing and ball joint play, it helps to have a partner. First pry under the tire with a pry bar. If you feel movement, have your partner pry on it while you watch the ball joints. If there is play you can usually see it. If its a small amount that you can't see, wrap your hand around it and try to feel for the movement.
If you feel looseness but don't see it in the ball joints, the play is from the wheel bearings.
jhedges15 is offline
post #9 of 9 Old 03-05-2013, 08:55 AM
Colt44
1983 CJ7
In a bit late, but AutoZone does carry a selection of the more common sockets for Ford, Chevy, Mopar, etc.
They might not have it in stock at every store, but search their website using the term spindle nut socket to get the part number for the size you need.
"We are all of us in the gutter...
Some of us are looking at the stars."
~ Oscar Wilde via Chrissie Hynde
Colt44 is offline
