what's your favorite 2bbl? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > what's your favorite 2bbl?
1989 Jeep Wrangler Clutch Kit with Slave Cylinder for L6 41987-1995 Jeep Wrangler Mirror Manual Folding Pair1987-1989 Jeep Wrangler Brake Pad & Rotor Kit Semi-Met
Unread 03-10-2009, 11:34 PM   #16
CJ258
1974 CJ5
I replaced the original head, intake and exhaust on my '74 with '87 YJ parts. The Rochester 2 barrel is the same size opening as the adaptor for the 2100 but still had to make my own adaptor plate and ported it to match the intake with the Rochester. The 2100 plate bolt hole overlapped the carb bolt holes.
CJ258 is offline   Reply With Quote Quick reply to this message
Unread 03-11-2009, 10:34 AM   #17
MikeMCJ
1951 M-38
thanks for answering.
MikeMCJ is offline   Reply With Quote Quick reply to this message
Unread 03-11-2009, 04:47 PM   #18
jeepdaddy2000
1971 CJ5
Originally Posted by 00bluedak View Post
Rochester 2 jet is the way to go!!! they are easy to find and dirt simple to work on. they are jetted a little rich for a 6 though since they came on v8's, but you can get new jets to easily fix that problem.
There are two sizes. One is 298CFM, the other I believe is 400. The larger is common on V8's while the smaller on V6's. My 225 came from the factory with the smaller version and it worked extremely well offroad.
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 03-11-2009, 08:40 PM   #19
SuB8HaVeN
Are you running the 1bbl or 2bbl intake manifold? My all-around favorite would have to be a Holley 2300 for simplicity, downright reliability, and easy tunability. I run the progressive Weber 34/34 on my CJ and it gets much better fuel economy than any other 2bbl, and still has some umph. IMO, the Holley is simpler and easier to tune than the Weber. The Weber 32/36, and Holley 5200 (basically a Weber 32/36 clone manufactured by Holley) are also both great carburetors and are very fuel efficient, being progressive 2bbls.
My CJ sees a lot of on-road driving, so fuel economy is pretty important to me. That's why I run a progressive Weber on there. If I was more into tuning it and getting the most performance I'd have a Holley 2300 on there.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline   Reply With Quote Quick reply to this message
Unread 03-12-2009, 01:43 AM   #20
CJ258
1974 CJ5
The smaller version is also the 2 5/8" neck and one I'm using has the 3 1/16" neck.
Unread 03-12-2009, 09:43 AM   #21
neals80
1980 CJ7
Hands down the MC2100....smooth smooth smooth
Neal Trombley
1980 CJ 7
SW FLORIDA
IF I WANTED A HUMMER I WOULD HAVE CALLED YOUR GIRLFRIEND!!
neals80 is offline   Reply With Quote Quick reply to this message
Unread 03-12-2009, 04:12 PM   #22
HackFabrication
1976 CJ5
Here's mine:
Edit: Oops... This happens when you just read the title, and not the whole post....
"In the end...It's all Hack."
HackFabrication is offline   Reply With Quote Quick reply to this message
Unread 03-12-2009, 05:12 PM   #23
scottymac62
1979 CJ7
MC 2100's. I have them on my CJ7 (258) and my CJ5 (304).
scottymac62 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2009, 10:28 PM   #24
mcmud
1983 CJ8
Gotta Winner Here
Originally Posted by HackFabrication View Post
Here's mine:
I'd say ALL TIME BEST EVER!
mcmud is offline   Reply With Quote Quick reply to this message
Unread 03-16-2009, 10:17 PM   #25
gimmesomerocks
^^ i prefer an over/under double barrel^^
anyhow, i was out @ the junkyard over the weekend and spotted an '81 Mustang with the 4 banger. I have some pics for you all to ponder over and tell me what you think. I really like the fact that it has a mechanical secondary and not vacuum. There is not much I know about these carbs, just that they were supposably weber carbs, marketed as holley, and I know nothing more. No idea how to id these weber carbs. I could not find an id tag on it anywhere, but I did not grab it or mess around too much with it as I was already on my way out with another cast iron anchor (this time a two barrel and from a fsj.) so, if anyone can look @ the pics and say yea, or can tell me how to better narrow down the model of the carb. unfortunately these are the only two pics I have and they were also taken with a smell fone. (wife won't let me take the dig. cam to the junkyard)
gimmesomerocks is offline   Reply With Quote Quick reply to this message
Unread 03-16-2009, 11:05 PM   #26
mcmud
1983 CJ8
Best pass on that 6520 I'd say. Missing the Power Valve Control Valve and Diaphragm. Lower right corner in first photo, and cause it has had a Power Valve Control Valve. It's a feedback carb looking for O2 sensor input. Look further for a 5200. It will not have that missing thing nor the E.A.V. Solenoid directly across the fuel horn on cover.
This photo, compliments of another JF user is what to seek. The Holley5200
