Whats wrong with my windshield??? - JeepForum.com
post #1 of 9 Old 05-19-2008, 07:24 PM Thread Starter
J98cherokee
Everything on my jeep is jerry rigged from the PO so now Ive got a new top and it doesnt want to fit quite right.
The hardware obviously isnt original but the only problem im having is hooking the front under the lip mounted on top of the windshield. It looks like the orginal hardware didnt have that extra curve, i think im gonna just cut an inch of each side assuming thats what the original was like??
Ive also got a pretty large gap between the door and the windshield but my measurement from top of windshield to rear is 66 1/2 inches. One inch shorter then the instructions. If I move the windshield back to close the gap it will probly be off two inches then. Any ideas?
http://i261.photobucket.com/albums/i...5/IMG_0334.jpg
http://i261.photobucket.com/albums/i...5/IMG_0338.jpg
http://i261.photobucket.com/albums/i...5/IMG_0333.jpg
J98cherokee is offline
post #2 of 9 Old 05-19-2008, 08:31 PM
illinicj
1979 CJ7
That looks like a Bestop front channel. My original didn't have that bend. Go with what fits your type of top, I suppose. Also, my buddy's YJ windshield measured perfectly per the Bestop instructions, but the windshield was too upright. We had to angle it back, further than they spec, in order for it to fit his hard doors perfectly.
illinicj is offline
post #3 of 9 Old 05-19-2008, 09:45 PM
bigjoe
1977 CJ7
The front channel sure does look like Besttop channel that my setup has on it. Give Besttop a call they maybe able to give you some help. Also it helps when top material is warm. Try mounting after you've have had top out in the sun for a little while before mounting. Goodluck.
bigjoe is offline
post #4 of 9 Old 05-19-2008, 09:53 PM
79BlackPearl
1979 CJ7
I have a 79 CJ7 and the curve is factory from Bestop. Also, my Bestop bikini front edge has a 3-piece metal bar that hooks into the channel. On each side (drive & passgr) the metal bar is about 1-2" long, that fits into the curved area, and the middle piece spans the distance in the middle.
Never tried to use mine with the hard-doors, so can't help you there.
Hope this helps with the "curve" of the channel.
79BlackPearl
79 CJ7, 3" Lift, 360 V8, Edelbrock Performer Intake, Comp Cam, Holley 650 Truck Avenger, Hedman Headers, Moser Axles, Herculiner, Warn M8000i, 33" Timberlines
Guaranteed to Make $$$$ with your Computer! No Risk Involved! Simply press shift-4 four times in a row.
79BlackPearl is offline
post #5 of 9 Old 05-20-2008, 05:53 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Is this a CJ7 or CJ5?
Well it is a Bestop Supertop channel as mentioned. So are those side stops on the wind shield on the inside. Did you get a Bestop Supertop?
All that hardware looks as if it's for a Supertop
If you got a Tiger top then you're going to need OEM hardware.
When you got the new top did you get new doors? Those look like the old ones.
I wonder what the snals down the side of the windshiels is for.
John Strenk is online now
post #6 of 9 Old 05-20-2008, 08:27 AM
joemac421
joemac421's Avatar
That window frame looks alot like the one from my 95 YJ, notice the bar mounting holes, the frame that run downs the side and the single piece with bends over the side are exactly like what I had on my YJ for the top channel.
Better to have Jeeped & Rolled Over then to never have Rolled Over.
joemac421 is offline
post #7 of 9 Old 05-20-2008, 08:41 AM Thread Starter
J98cherokee
update:**NOTE TO ALL**: A replace a top does in fact need original factory hardware. haha. It is close to mounting on supertop hardware...but... not close enough. Guess im an idiot. Not to mention the doors are completely different as well. Looks like I will be shopping again.
"Its a '76 cj5. I bought it from a guy on craigslist and I believe it is a replace a top that just gives the skin and uses factory hardware.
The top on before it probably was a super top hints the hardware for it which would make since in why the replace a top doesnt want to fit the windshield mounting piece.
And yes those are the old doors I had with the other top.
Another quick question. Does anyone know if I can mount the replace a top factory skins on the super top door frame besides the door handle being different??
I think it will mount ok if I cut whats needed off the curved part (thats if besttop wont sell me an individual piece). Then if I ever get a supertop I will just get new hardware with it."
post #8 of 9 Old 05-20-2008, 10:01 AM
CJ Chet
Looks like those curved pieces might be bent in on the end. Had that problem with mine. Just bent them back out a little with a screwdriver.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #9 of 9 Old 05-20-2008, 02:32 PM
John Strenk
1976 CJ5
Might want to read this if you want to see what's in a CJ5 Supertop. You can then deside if you can put on a different top.
http://cjoffroad.com/writeup.asp?WU_ID=28&noAdd=1
Whats wrong with my PS pump - gets HOT DuggerCJ Jeep CJ Forum 3 08-10-2009 10:06 PM
Replaced Hi pressure power steering line. Whats wrong slick351 Jeep CJ Forum 4 11-08-2008 10:08 AM
ANy idea whats wrong with my axle? jeepin cj-5 Jeep CJ Forum 7 02-13-2006 05:01 AM
New windshield frame - whats wrong? JeepJedi Jeep CJ Forum 10 04-16-2005 02:20 PM
Whats Wrong????????? DEERSLAYER1407 Jeep CJ Forum 10 11-16-2004 07:29 PM
