Whats Wrong With My Jeep!! - JeepForum.com
post #1 of 9 Old 11-07-2011, 04:18 PM Thread Starter
kannabisking
1952 CJ3A
Ok, I bought a cj5 about a month or two ago and I tried to hook up a battery to fire it up....but once i try to attach the negative cable(after positive is attached) the engine turns over even when the key is out. so I replaced the solenoid twice and the ignition switch. after i installed both the switch and solenoid i hooked up the battery and nothing so i cranked it over and it worked as it should but then after i tried it a second time it did the same thing as before. I've looked at all the wires and they all look fine, and i completely switched the wires around on the solenoid and nothing different. i cant think of anything it could be other than what i tried already so hopefully someone on this forum that actually knows what they're doing can help.
Idk if this helps.... but before i replaced the ignition switch the previous owner used a flathead screwdriver to start it.
kannabisking is offline
post #2 of 9 Old 11-07-2011, 04:56 PM
sarfu
1974 CJ5
Had the same problem, turns out the electrical connections to the Ignition switch were loose, I wrapped it with electrical tape and have not had a problem in months.
sarfu is offline
post #3 of 9 Old 11-07-2011, 05:12 PM
KJNewbs
1983 CJ7
I read a thread recently while researching my solenoid, alternator and starter wiring where a guy had this same problem. I'll see if I can dig it back up. I believe that the suggestions were to confirm the wiring from the switch to the solenoid to the starter. As Sarfu mentioned, it is probably a wiring issue (be it a loose or shorted connection) - something is making the circuit before you tell it to.....
-KJ Newbs / Jersey
1983 lime green CJ7 - 258 with DUI & Weber, Crane cam, 2" lift, MTs w/ BFGs
2010 2-Door, 6-Speed Black JK Sahara - Teraflex 3" Coil Lift with Front Lower and Rear Upper Flex Arms - Bilstein 5100 Shocks -JKS Front Adjustable Track Bar - Teraflex Front Knuckle Gussets - Rock Hard Oil Pan/Engine Skid - Rock Hard Transfer case skid - Rock Hard Evap relocation Kit - Poison Spyder Rocker Knockers - MBRP off-road exhaust - AEV Pintler Wheels - GoodYear MTR/K 35x12.5x17 - Detroit Track Loc Carrier up Front - Yukon 4.88 Gears - Cobra 75 CB with Cool Tech bracket - Die-Tech mirror relocation brackets
KJNewbs is offline
post #4 of 9 Old 11-08-2011, 07:27 AM Thread Starter
kannabisking
1952 CJ3A
Hey sarfu Ill double check that, getting behind them jeep dash's is a ***** though, haha(btw my cj is a 74' also). And kjnewbs, if you can find that thread i would appreciate it. not being able to wheel in my newest jeep is really pissing me off
post #5 of 9 Old 11-08-2011, 07:29 AM
Moto4x4
In soviet russia, the problem would be you
nah i have nothing to contribute, just trolling. Hope you find your answer soon
Moto4x4 is offline
post #6 of 9 Old 11-08-2011, 07:51 AM
stodg73
1979 CJ5
Check to make sure that your starter solenoid is wired right. This may cause the problem that you are having. My finger is pointing to the cable from the battery.
'79 CJ5, 258 c.i., Carter BBD, T-150, Dana 20, Dana 30, AMC 20, 33x12.50x15, 3" body lift, taking it back to stock, then tearing it apart and putting it back together again!
stodg73 is offline
post #7 of 9 Old 11-08-2011, 06:07 PM
BagusJeep
1981 CJ7
Try taking off the control wires from the solenoid. Just leave the battery cable and the starter feed connected. Doe sit still do it? If so then solenoid.
If it only does it when the control wires are connected then it is either a short or an issue with the switch. If the PO was starting it with a screwdriver shoved in the side of the column there is a fair chance you have an issue with the lock to rod to switch.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 9 Old 11-16-2011, 01:30 PM Thread Starter
kannabisking
1952 CJ3A
Ive checked the solenoid wires and they all seem to be in place. And bagusjeep ive tried what you said and it still did it....but even after i changed the solenoid(twice!) it still did it
post #9 of 9 Old 11-16-2011, 03:51 PM
sillykid
is your solenoid grounded to the fender properly? if you place a jumper between the two posts on the solenoid will it fire?
sillykid is offline
4x4 , cj5 , electrical , fix , jeep
Whats wrong with my PS pump - gets HOT DuggerCJ Jeep CJ Forum 3 08-10-2009 10:06 PM
Whats wrong with my windshield??? J98cherokee Jeep CJ Forum 8 05-20-2008 02:32 PM
ANy idea whats wrong with my axle? jeepin cj-5 Jeep CJ Forum 7 02-13-2006 05:01 AM
New windshield frame - whats wrong? JeepJedi Jeep CJ Forum 10 04-16-2005 02:20 PM
Whats Wrong????????? DEERSLAYER1407 Jeep CJ Forum 10 11-16-2004 07:29 PM
