What's The Latest Model Year CJ 7 With NO MICROCHIPS of Any Kind? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > What's The Latest Model Year CJ 7 With NO MICROCHIPS of Any Kind?
New! JK/U skid plate system.We now have Uniballs!The Original 3/8" Ruffstuff Diff Cover!
Unread 03-02-2014, 07:10 PM   #1
WLJ
I want a CJ7 with no microchips of any kind in it.
What is the latest year model with no chips?
I guess another way to ask the question would be to ask what was the first year model CJ7 to have a microchip?
WLJ is offline   Reply With Quote Quick reply to this message
Unread 03-02-2014, 07:52 PM   #2
rplivin
As long as you live in a state with no emissions go with what ever year you can find and do away with the computer. I would stick with the wide track years jmo and do the nutter bypass and weber upgrade.
rplivin is offline   Reply With Quote Quick reply to this message
Unread 03-02-2014, 08:55 PM   #3
chromegrille
1947 CJ2A
Depends on state, model year, and engine.
chromegrille is offline   Reply With Quote Quick reply to this message
Unread 03-02-2014, 09:05 PM   #4
WLJ
It seems there are no easy answers to questions about these things.
I just want a CJ with no microchips!
I thought California was the only pain in the rear state when it came to smog during the years the CJS were built.
Unread 03-02-2014, 09:19 PM   #5
chromegrille
1947 CJ2A
Make it 1975 and prior then.
No electronic nothing.
Unread 03-02-2014, 10:25 PM   #6
seabass1858
seabass1858's Avatar
1983 CJ7
and remove the radio also. joking but yea 75 and prior would your best bet but i hear certain restoration parts are hard to come by.
seabass1858 is offline   Reply With Quote Quick reply to this message
Unread 03-02-2014, 11:56 PM   #7
stgil
1982 CJ7
1986 CJ7 Diesel: fully mecanic! and hydraulic: steering and clutch
FULL DANA 30 REBUILD->http://www.jeepforum.com/forum/f8/cj7-dana-30-full-rebuilt-setup-part-i-1121189
'82 CJ7 LAREDO REBUILD->http://www.jeepforum.com/forum/f8/82-cj7-laredo-diesel-restoration-1179198/
stgil is offline   Reply With Quote Quick reply to this message
Unread 03-03-2014, 12:39 AM   #8
jp360cj
1977 CJ7
Just curious why y'all are saying '75...the computers didn't make their way into CJs until sometime in the 80s
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline   Reply With Quote Quick reply to this message
Unread 03-03-2014, 02:15 AM   #9
John Strenk
John Strenk's Avatar
1976 CJ5
He said he didn't want any microchips.
Some of the 76 and later CJ's had electronic ignition systems. 76-77 had Prestolight ignition system and after that came the Duraspark ignition system.
Some of these used microchips although not computer chips per say, they still uses silicon based components.
California had computers as far back as 82 and all CJ's had computers since 84.
[Grammar]
Grammar check on post #9 please.
Which is correct?
"1976 to 1977 HAD a Prestolight ignition system"
or
"1976 to 1977 HAS a Prestolight ignition system"
In 1976 to 1977 they USED the Prestolight ignition system and chances are, if you buy a 1976 to 1977 CJ, it will still HAVE a Prestolight ignition system.
[/Grammar]
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 03-03-2014, 04:33 AM   #10
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Mallory still make a dual point distributor that will fit on any Jeep carb engine so that can take you up to 91 or so I think.
With just a coil and points, the stock carbs can be tuned to run well with no microchips in the circuit and they will pass the emissions sniffer/dyno test.
The Nutter Bypass thread outlines how to manually set them all up with no computer controls using any ignition system, points or electronic.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 03-03-2014, 05:00 AM   #11
FLynes
FLynes's Avatar
1976 CJ5
[Grammar]
Which is correct?
or
[/Grammar]
John,
WTH are you doing awake at 3AM????? Grammar...."1976 to 1977 HAS a Prestolite ignition system", since there are still 1976 and 1977 CJs on the road.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
Grammar Test
FLynes is offline   Reply With Quote Quick reply to this message
Unread 03-03-2014, 06:49 AM   #12
ScroungerLee
Originally Posted by FLynes View Post
John,
Unless the Prestolite ignition system was replaced with something else in which case it HAD such a system
ScroungerLee is offline   Reply With Quote Quick reply to this message
Unread 03-03-2014, 07:11 AM   #13
macscal
1978 CJ5
Sounds like the o.p. wants an EMP proof jeep.
macscal is offline   Reply With Quote Quick reply to this message
Unread 03-03-2014, 07:57 AM   #14
John Strenk
1976 CJ5
John,
Only 4:00 EDT.
It's when I start work 6 days a week. We start overtime before our normal shift.
Thanks for the insight.
It was driving me crazy that I could not figure out whether to use 'HAD' or 'HAS' in the sentence. I had good arguments in my head either way.
I only missed 1 question on your grammar test...
Unread 03-03-2014, 08:04 AM   #15
CSP
The first year of Prestolite in a CJ was 1975, not '76.
CSP is offline   Reply With Quote Quick reply to this message
