Whats the best way to clean the underbody - JeepForum.com
post #1 of 6 Old 02-27-2013, 07:27 PM Thread Starter
tmholland
1980 CJ5
I am working on cleaning up the underside of my cj5, I have grease, oil and dirt build up that I would like to remove. After doing this I would like to repair any rust areas (whats the best thing to use), then I would like to coat the under side
tmholland is offline
post #2 of 6 Old 02-27-2013, 07:37 PM
Ivehad4
1978 CJ7
Probably easier ways but I hand-scraped the muck, cleaned the rest of the grease off with rags and mineral spirits, then wire-wheeled the whole thing. Gave my drill a real work out.
1978 CJ7 304/T150
1959 Willys CJ5 F4/T90
1995 XJ 4.0
1998 TJ 4.0
Ivehad4 is offline
post #3 of 6 Old 02-27-2013, 07:57 PM
aufan
I am in e process of tearing apart a axle. I used brake cleaner and a wire wheel. The wire wheel works fast and really cuts down the old layers of crud.
aufan is offline
post #4 of 6 Old 02-27-2013, 09:41 PM
kappa505
1980 CJ5
Dollar store oven cleaner.
"Nothing in the world can take the place of Persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan 'Press On' has solved and always will solve the problems of the human race." Supposedly President Coolidge
kappa505 is offline
post #5 of 6 Old 03-01-2013, 07:48 AM
Dmed77
1966 CJ5
I am in the process cleaning up my undercarriage, had lots of surface rust, grease and grime buildup. I applied a degreaser, then power wash, now I am using a drill (with a wire wheel attachment) and a grinder with wire wheel and hitting everything from the frame to differentials. After I get all the surface rust off I am thinking about using the KBS rustseal product and painting it.
Dmed77 is offline
post #6 of 6 Old 03-01-2013, 07:49 AM
Balvar24
1979 CJ7
Creek
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
