Whats the best way to clean off gear lube? - JeepForum.com
post #1 of 8 Old 02-22-2013, 02:09 PM Thread Starter
CrankyD
1983 CJ7
Right now I have my T-5 and Dana 300 on the bench due to my starter eating the ring gear. Whats the best way to clean out all the old gear lube while I'm in there freshening up? I plan to go back with gear lube in both as they look pretty good for their age and thats what I've been running.
CrankyD is offline
post #2 of 8 Old 02-22-2013, 02:20 PM
agear
Brake parts cleaner in an aerosol can, but what do you mean by freshening it up ? Unless you're going to take everything apart and put it back together again using lube as you go , then I wouldn't try to remove it all. You want the oil in the hard to reach places.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #3 of 8 Old 02-22-2013, 02:30 PM Thread Starter
CrankyD
1983 CJ7
I mostly need to clean up the inside of the case and a few stubborn sludge deposits. I don't want to use a water based product.
CrankyD is offline
post #4 of 8 Old 02-22-2013, 02:43 PM
agear
I see. You could do some spot cleaning with brake cleaner unless it's water based.........?
agear is offline
post #5 of 8 Old 02-22-2013, 03:17 PM
Ivehad4
1978 CJ7
I use mineral spirits. Not too harsh for seals but pretty effective on cutting the gear oil.
1978 CJ7 304/T150
1959 Willys CJ5 F4/T90
1995 XJ 4.0
1998 TJ 4.0
Ivehad4 is offline
post #6 of 8 Old 02-22-2013, 04:13 PM Thread Starter
CrankyD
1983 CJ7
Water based like as in purple cleaner or dish detergent. Brake cleeaner isn't water based.
CrankyD is offline
post #7 of 8 Old 02-22-2013, 04:37 PM
agear
Well then brake cleaner works great
agear is offline
post #8 of 8 Old 02-23-2013, 11:26 PM
james04si
james04si's Avatar
1977 CJ5
Some diesel or even gas if you live life on the edge. I have a 20 gallon parts cleaner filled with diesel and it cleans anything.
james04si is offline
