What year wrangler or cherokee has the best ax-15 that will fit a cj7 258 - JeepForum.com
post #1 of 8 Old 02-16-2012, 09:00 PM Thread Starter
musclenut
1982 CJ7
I'm wanting to swap the t-4 that's in my 82 cj-7 with a 258 out with a ax-15 What years wrangler or cherokee is best for the swap?
musclenut is offline
post #2 of 8 Old 02-16-2012, 11:27 PM
BagusJeep
1981 CJ7
94-99 with the external slave cylinder.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 8 Old 02-16-2012, 11:48 PM
1986cj
2x on the 94-99 external. I have never had a Jeep with ether, but I had a Ford Bronco II and my son has a Ford Explorer and both have a internal hydraulic thought out bearing. What a joke they are for something that you are going to wheel and give the clutch a good work out. Adjustment? aint none.
1986cj is offline
post #4 of 8 Old 02-17-2012, 01:21 AM
n3vrknowitwasme
1983 CJ7
Would like to see a build thread for this!
n3vrknowitwasme is offline
post #5 of 8 Old 02-17-2012, 02:20 AM
BagusJeep
1981 CJ7
You wish is my command, oh great never knew it was you:
JeepForum.com > Models > Jeep CJ Forum > Official 4.0 AX-15 swap thread
post #6 of 8 Old 02-17-2012, 06:22 AM Thread Starter
musclenut
1982 CJ7
What are the best years of wrangler or cherokee to nab an efi system from, and the head and manifolds for a 4.0 head conversion?
post #7 of 8 Old 02-17-2012, 06:35 AM
Area.3.Fiftyone
FWIW: You can convert any internal AX15 to external by swapping the bellhousing, input shaft snout and fork.
Same goes for an AX5.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #8 of 8 Old 02-17-2012, 07:10 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Just a note. Virtually all hydraulic clutch systems are self adjusting at the slave cylinder. They are designed for the t/o bearing to be in contact with the clutch at all times. The slack is taken up by the cylinder itself, much like a hydraulic cam lifter.
As for the internal versus external slaves, there are pluses and minuses to both. Internal cylinders eliminate forks and pivot points, provide even pressure around the t/o bearing, and are shielded against most of the dirt and debris that get driven up against the side of the bellhousing. Their greatest downfall to me is if one goes bad, well, lets just do a clutch while we are in there.......
jeepdaddy2000 is offline
20+ year old Goodyear Wrangler R/T's - are they worth anything 78JeepFun Jeep CJ Forum 9 04-23-2011 08:22 PM
What year? sjwrangler Jeep CJ Forum 2 01-21-2009 08:17 PM
CJ8 - what's the best year to buy? 90SaharaJeep Jeep CJ Forum 7 03-17-2006 05:03 PM
What Year Is My 3a? blackyj Jeep CJ Forum 3 05-30-2005 01:33 PM
what year is it? rustyCJ Jeep CJ Forum 19 12-07-2002 05:33 PM
