what year could this jeep be - JeepForum.com
post #1 of 12 Old 09-02-2008, 08:29 PM Thread Starter
Luckyduck
I am going to look at my 4th jeep tomorrow (i have a 57 cj5 99 tj and a 98 xj) So I know a lot about jeeps now I am going to look at an 84 cj7. http://worcester.craigslist.org/cto/821872711.html
He told me it is an 84 with the 304 and a 3 speed manual and 98000 miles. I thought that they stopped putting the 304 in the cj's in 81. any idea if they even made a 3 speed manual for the v8? and what years they where available.
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build
Luckyduck is offline
post #2 of 12 Old 09-02-2008, 08:36 PM
onesourcemike
1983 CJ7
get the Vin!!!
onesourcemike is offline
post #3 of 12 Old 09-02-2008, 08:36 PM
LostINohiO
the jeep probably is an 84
the motor may have been swapped...
jot down the VIN and run it through one of the myriad of "jeep vin decoder" s on google...
then you will at least know where the VIN plate and title have been.
2 grand isnt bad.
buy it then sell me the hard top.
1985 cj7
LostINohiO is offline
post #4 of 12 Old 09-02-2008, 08:45 PM Thread Starter
Luckyduck
Ya I will get the vin tomorrow. The guy had a heavy accent so I just decided to get it tomorrow. The way I see it is if it has no rust then it is worth it. but they did make a 3 speed manual for the 304?
CentralMass4wd.com
my build
post #5 of 12 Old 09-02-2008, 08:55 PM
jeff83
The T150 is a three speed
R 2
l l
1 3
build it, wheel it, break it, repeat
1983 CJ 7 (traded for TJ)
1992 YJ Renegade (sold)
1999 XJ Classic (daily driver)
1997 TJ Sport (building)
jeff83 is offline
post #6 of 12 Old 09-02-2008, 09:01 PM Thread Starter
Luckyduck
R 2
l l
1 3
Same shifting pattern my 57 has
CentralMass4wd.com
my build
post #7 of 12 Old 09-02-2008, 09:55 PM
jeepskate
It's a hodge-podge from what I can see...I'd venture that the VIN isn't legit/doesn't match. Looks like it's a narrow track ('84 would be wide track) which would be in line with a 304/T-150 combo and I'll bet it's backed with a Dana 20 ('84 would have a Dana 300 which doesn't bolt up to the T-150). YJ rear flares and side steps are an obvious retro-fit (no biggie, just something to point out).
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #8 of 12 Old 09-02-2008, 10:19 PM Thread Starter
Luckyduck
I noticed the yj flares, but lots of people put tj flares on yj's so i disregarded that. So Jeepskate you know more about this style than me what should I look for to get a pin point on this thing? As you could probably tell I know plenty about early cj 5's 97+ xj's and tj's I also have done lots of research on yj's and just recently some on jk's (looking for a friend) but never really read up on the cj7's.
so basically how to i pick out differences between everything?
CentralMass4wd.com
my build
post #9 of 12 Old 09-02-2008, 10:49 PM
jeepskate
A lot of it you just glean from being around the stuff. I have an inherent distrust for folks who try to make something look like something it isn't (make a LeMans look like a GTO, etc) particularly when they put it up for sale. The guy was clearly trying to make this rig look more like a YJ. The door handle style is correct for '82 and up, the drivetrain is wrong for the year as the 304/T-150 combo wasn't used after 1979...the Dana 300 t-case was introduced in 1980 and the transmission choices changed and the 304 finally bowed out in 1981. Check the axle width...56" WMS would be correct for a wide-track (1982-1986). Look at the front upper shock mounts...wide tracks used bolt on shock towers, narrow tracks used short stud brackets welded to the frame. Earlier model would also have an extra rear crossmember near the rear shock mounts on the frame. Look this puppy over very closely.
post #10 of 12 Old 09-03-2008, 04:01 PM
Smtty58
Duck, what are you doing in the CJ forum?! I wish I had more notice, I would have gone with you, only about an hour from me.
90 YJ, 4.2, AX-15
86 K1500, 305, 700R4
Smtty58 is offline
post #11 of 12 Old 09-03-2008, 05:23 PM
bigjoe
1977 CJ7
Sounds like my 84'. PO swapped in a 304. Vin should answer it's background.
bigjoe is offline
post #12 of 12 Old 09-03-2008, 07:10 PM Thread Starter
Luckyduck
Ya I am here from time to time. Me and my dad are restoring a 57.
I looked at it and it was not in bad condition. was lifted on 33's with along with a suspension lift there was a 3 in body had a swapped in 304 with headers and true dual exhaust no cats Vin showed it is an 84 with the 4.2.
CentralMass4wd.com
my build
Jeep CJ what year is block alisa65 Jeep CJ Forum 3 08-25-2009 06:58 AM
What year is this Jeep? Randn918 Jeep CJ Forum 8 01-10-2009 07:43 AM
trying to figure out jeep year 84 400 Jeep CJ Forum 5 05-04-2007 08:14 AM
What year jeep? HELP Jeepman99 Jeep CJ Forum 10 06-11-2006 10:00 PM
The Best Year of Jeep CJ?? KyleCox Jeep CJ Forum 5 03-12-2002 09:37 PM
