what year carb? and vacuum question - JeepForum.com
post #1 of 5 Old 05-24-2003, 09:20 PM Thread Starter
jeepster18_88
Well, I've finally ran into the inevitable problem with the BBD carb. I am considering doing a nutter bypass, but I hate to go through the trouble and still have that the vacuum lines and wiring in my way. I don't want to spend the money on a Holley or Weber till I can build up the motor. I am also considering an older 2 barrel Carter, without the feed back system, but don't know what years they came on.
My goal is to replace the BBD with a 300-400 cfm carb and get rid the emissions headache.
What all vacuum lines do I need when I get rid of the emissions?
What years did the non-feed back carb come on the jeep?
What are your suggestions for a carb swap for under $200?
Thanks for any and all help!
Josh
jeepster18_88 is offline
post #2 of 5 Old 05-25-2003, 01:39 PM
knowlwk@snowhill.com
1980 CJ7
Motorcraft 2100... kick-butt cheap carb upgrade.
Needs: used MC2100, adapter, air cleaner, rebuild kit... $75-$150
On a CJ you need vacuum to distributor, pcv to manifold vacuum, and probably breather to air cleaner... the rest can be junked.
Search for "Motorcraft swap" on google... there are at least 5 good write-ups. Also, ebay is probably the easiest place to find a carb if you don't have a good junkyard near you or don't have time to search yourself. Summit has the adapter and air cleaner, any auto parts place should have the rebuild kit, but you'll need to know what vehicle your used carb came off of as there seems to be MANY variations on the MC2100/2150 and you'll need a kit with the correct gaskets...
MC2100 is as good or better than the Weber (I've run both on the same jeep.. stuck with the MC2100).
'80 CJ7, 258 W/Autojuicer, MC 2100, TFI, SummitRacing CDI, MORE SRS, Moser 1-pc, YJ tub on 1" body lift, YJ family cage.
knowlwk@snowhill.com is offline
post #3 of 5 Old 05-25-2003, 06:37 PM
HighCountry
BEWARE!!!
In many counties of Texas around Houston, Corpus Christi and Dallas-Ft Worth you MUST have ALL original "Smog Crap" ON the vehicle AND it must pass a tailpipe sniffer test. This inspection will almost certainly be going statewide some time in the future, so don't DO things that you can not UN-do!
I just moved across the border to Arkansas a few months ago, so am very familiar with the Texas Inspection. I have friends trying to deal with it in Dallas and Corpus Christi.
Bruce from West LA (Lower Arkansas)
HighCountry is offline
post #4 of 5 Old 05-26-2003, 09:49 AM
1980 CJ7
Good point, we don't have emissions inspections yet here in AL, and my jeep didn't have any vacuum goodies left by the time I got it... but you may have to have them to run in your state.
post #5 of 5 Old 05-26-2003, 04:18 PM Thread Starter
jeepster18_88
Thanks! I'll look into the 2100. I bought my Jeep from my uncle who lives in Houston. He couldn't get the jeep to pass emissions so he finally decided to sell it. I think one of his major problems was that the vacuum lines are all out of place. Obviously the shop that he had work on it, couldn't understand the vacuum diagram. I live in a small town about 75 miles from downtown Houston so I am a little worried about emissions. Hopefully by the time it gets here I'll be able to fuel inject it or just use it for a huntin' buggy. Thanks again.
Josh
2.5 Carb Vacuum Question... poppatello Jeep CJ Forum 2 08-05-2008 05:24 PM
Carb vacuum hose 78 Cj5 Help!!! 5StarRising Jeep CJ Forum 4 04-04-2007 12:56 AM
Carter carb vacuum question..... h2oman Jeep CJ Forum 4 04-05-2005 09:51 PM
One Weber carb question, vacuum line? fromme Jeep CJ Forum 2 10-21-2004 09:00 PM
Stock 151 Carb Question (Not about vacuum this time!) Aphelion79 Jeep CJ Forum 0 11-05-2003 09:46 PM
