what year is it? - Page 2 - JeepForum.com
post #16 of 20 Old 12-03-2002, 08:00 PM
BART CJ5
BART CJ5's Avatar
1979 CJ5
D44's were used from '70-'75, '86 CJ7's and '97-'02 TJ's.
The AMC 20 was used from '76-'86.
D30's were used on the front from '72-'86
A D20 is a transfer case that was used from '72-'79
The Model 300 was used form '80-'86
If you have discs on the front the '77-'78 used the six bolt caliper plate.
'78-'86 used 2 bolt caliper plate.
BART CJ5 is offline
post #17 of 20 Old 12-03-2002, 09:40 PM Thread Starter
rustyCJ
it was a 79!
the jeep is now in eight pieces and in the scrap metal pile at the recyclers here. a 258 block with a hole in it, a 79 rusted out frame, and a completely gutted tub that had some serious rust issues got me $63.47 in scrap. cutting a frame with a sawzall isnt fun and you will go through a few blades.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #18 of 20 Old 12-04-2002, 07:33 PM
BART CJ5
BART CJ5's Avatar
1979 CJ5
Sounds like you need a torch Rusty. So you just kept the axles, trany and transfer case?
BART CJ5 is offline
post #19 of 20 Old 12-04-2002, 08:44 PM Thread Starter
rustyCJ
i basically kept everything, the only things that went with the tub and frame were the plastic vent box thing and the orig center console, it was missing the lid.
and yeah, i need a cutting torch. giving one away?
rustyCJ is offline
post #20 of 20 Old 12-07-2002, 05:33 PM
Bulletproofcj7
Originally posted by Jami
I don't know if it is a 79 because of the axles. The AMC 20 was only used after 80. If it is the original axle. If it were a 79 it would have a Dana 44 rear I believe.
Maybe im reading your post wrong, its a little confusing but..
The amc model 20 was used up untill early 1986. im not sure when it was introduced. there were two versions, narrow trac was the earlier version and wide trac was the later. i believe they made the transition around 1980.
The dana 44 was only offered in late 1986 in cj7's. and in the earlier 1970-75 cj5's (narrow trac)
I believe that the 6 bolt caliper plate was used until atleast 1978 as well as the 6 bolt hubs used until 1981
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
Which year for me? fastener Jeep CJ Forum 15 07-28-2009 08:01 AM
What Year? MDCJ Jeep CJ Forum 7 05-21-2007 08:40 AM
what year CJ5 do I have? mustangdave357 Jeep CJ Forum 19 05-09-2007 06:26 AM
What Year Is My 3a? blackyj Jeep CJ Forum 3 05-30-2005 01:33 PM
Which year... 3fifty Jeep CJ Forum 10 02-12-2005 01:22 PM
