What windshield frame should I buy? - Page 2 - JeepForum.com
post #16 of 29 Old 02-16-2010, 07:11 PM
1976j10
1976 J-Series Truck
I'd hunt for a used one.
1976j10 is offline
post #17 of 29 Old 02-17-2010, 02:21 AM
littleturner76
1984 CJ8
Originally Posted by NelsonATC View Post
You could always use a YJ windshield. Works well, just need to cut holes for the defrost, which his fairly simple. Plenty of writeups on this.
I found a used YJ windshield for my CJ8. cut out a few holes, and glued in a new windshield. Pretty easy swap. Just keep in mind the wiper linkage is not interchangable.
1984 CJ8 Scrambler, 258, MC2100, daystar 1", 4" Skyjacker Soft Ride, 31X10.5 on stock wheels, raptor lined.
littleturner76 is offline
post #18 of 29 Old 02-17-2010, 06:46 AM
Mike1084
1979 CJ7
My new frame had strength issues around the windshield wiper area which I had to reinforce. In addition the rubber cowl did not fit and seal the lip. As the aftermarket frames are prone to rust I'd recommend as soon as you get one to prep it and seal or paint as soon as you can.
For what it's worth I found a website/salvage yard that has some used ones. JEEP Windshield Frame - JEEP Junk Yards - JEEP Salvage Yards
Mike1084 is offline
post #19 of 29 Old 02-17-2010, 09:05 AM
wm69
so did you retain YJ wiper linkage and rig it to CJ wiper motor or ???
wm69 is offline
post #20 of 29 Old 02-17-2010, 09:24 PM
littleturner76
1984 CJ8
I had the enire yj assy including the motor just had to cut/slice the wiring for hi and low. I think the cj motor will work with the yj linkage. my motor and linkage was "M.I.A." when I bought my jeep.
post #21 of 29 Old 02-18-2010, 12:06 AM
apfroggy0408
1982 CJ7
So like an idiot I hit a tree with the side of the windshield. I was wondering what options I had when it comes to this. I'll get pictures in the morning but basically what is wrong is where it's hit it is dented in and the windshield frame is bent inwards.
Now luckily it's warm around here so I have no need to put doors on or hardtop on til next winter.
I have contacted a local jeep junkyard and he told me a windshield for my jeep would cost 150. Now that's not THAT much money but it is a pretty penny.
Can dents on the very side be fixed by someone who does body work and also made to align with the top again for less than 150?
I guess it will help when I get the pictures up.
apfroggy0408 is offline
post #22 of 29 Old 02-18-2010, 12:09 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I saw a pic of a Jeep in SKT's Acme hardtop thread where there was a strip of diamond plate along the bottom face of the frame where the wiper pivots are. Maybe trying to strengthen a thin wiper pivot mounting surface?
Rick
Cutlass327 is offline
post #23 of 29 Old 02-18-2010, 01:45 PM
apfroggy0408
1982 CJ7
Here are the pictures.
post #24 of 29 Old 02-18-2010, 01:58 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
My reading of history convinces me that most bad government results from too much government. -Thomas Jefferson
Off topic, but I like that!
Rick
post #25 of 29 Old 02-18-2010, 02:20 PM
apfroggy0408
1982 CJ7
Thomas Jefferson is my hero.
post #26 of 29 Old 02-19-2010, 12:43 AM
pazur
1981 CJ7
making 4-5" cut along the corner will allow you to straighten this bend, then weld, putty, sand, paint. You may have problems finding non-rust frame like yours at junkyards.
pazur is offline
post #27 of 29 Old 02-19-2010, 09:11 AM
apfroggy0408
1982 CJ7
Now I know I have all the tools needed to do those things but do you believe that this could be fixed by a body shop for a decent price? I'm not sure if I'm ready to start cutting up my jeep but I guess you have to start somewhere. I'll only do it if it will save a lot of money.
post #28 of 29 Old 02-19-2010, 11:48 AM
Ronzi
1983 CJ8
Ive installed a fiberglass windshield on 2 jeeps and have never had any problems. Just curious about what problems others have had with the fiberglass units. It was a pain installing the wiper linkage but it wasnt that big a deal.
Ronzi is offline
post #29 of 29 Old 02-19-2010, 12:17 PM
wm69
Mine had no reinforcement around the wiper pivot points. I haven't used my wipers much since I installed it, but I need to rinforce that area somehow to keep the wiper pivots from moving like the are now. That will lead to a bind, which will break something.
wm69 is offline
Windshield Compatibility - CJ7 windshield to replace a '76+ CJ5 frame? kbazurpe Jeep CJ Forum 3 08-30-2008 10:02 PM
Windshield Frame likeshills08 Jeep CJ Forum 10 03-19-2008 07:57 AM
Windshield Frame DeltaSigCJ5 Jeep CJ Forum 1 10-29-2007 09:15 AM
TJ windshield frame on CJ? rustyCJ Jeep CJ Forum 3 04-14-2003 05:30 PM
YJ tub & windshield on CJ-7 frame Brock Jeep CJ Forum 4 02-23-2003 08:17 AM
