What is this, and why doesn't bobbybare have one? - JeepForum.com
post #1 of 5 Old 07-04-2010, 03:39 PM Thread Starter
walkerhoundvm
1981 CJ8
About six inches above the starter on the block, just behind the coil. One black wire coming from bell-shaped arm, a dual-pin connector with two wires coming from the other one.
walkerhoundvm is offline
post #2 of 5 Old 07-04-2010, 04:19 PM
bruteboy
the bell shaped one looks like an oil pressure sending unit
bruteboy is offline
post #3 of 5 Old 07-04-2010, 04:31 PM
Trapshooter
x2...that is the oil pressure switch.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #4 of 5 Old 07-04-2010, 04:36 PM
Mike Romain
The single line off the top sends the oil pressure signal to the dash gauge and the two down front are the oil pressure switch that turns on the choke so it will open and under carb heater as soon as the engine has oil pressure.
Mike
Mike Romain is offline
post #5 of 5 Old 07-04-2010, 06:38 PM Thread Starter
walkerhoundvm
1981 CJ8
Awesome, that was a huge help. I think in my case, the front plugs go nowhere. I have a manual choke and an aftermarket intake/carb set-up. One less thing to have to worry about when I finally put in a new wiring harness!
-N
