What tub- liner is best - JeepForum.com
post #1 of 6 Old 03-11-2003, 08:50 PM Thread Starter
jeepin cj-5
I want to tub out my cj but I was wondering what was the best liner out there... rhino is too expensice.. i just want a do it yourself thing that is durable and easy to do.
jeepin cj-5 is offline
post #2 of 6 Old 03-12-2003, 10:50 AM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
I'm happy with the Herculiner - my friend has Duraback in his and is equally as happy. Both cost about the same - in the neighborhood of $100. The Herculiner is available in many auto parts stores and elsewhere but the Duraback is (or at least was) an order item only.
Steve
OldJeepguy is offline
post #3 of 6 Old 03-12-2003, 11:07 AM
BART CJ5
BART CJ5's Avatar
1979 CJ5
Definetly Herculiner.
BART CJ5 is offline
post #4 of 6 Old 03-12-2003, 01:38 PM
mxg342
mxg342's Avatar
I would say that you will get good results with both as long as you take your time with the prep work. I know one person that hurried through and it peeled almost immediately. The other friend took his time and it stayed rather nicely. If I had my choice though I would probably use hurculiner as it was the stuff that stuck.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #5 of 6 Old 03-14-2003, 09:07 PM
RODDOR
I used Hurculiner in the tub of my CJ5. I would say for the prep work use a drill and scuff the paint and be sure to get any surface rust off. I've had mine on a year and no problems. I have cheap carpet over mine, but it makes the interior look real good.
RODDOR is offline
post #6 of 6 Old 04-06-2009, 02:38 PM
jsc7002
1966 CJ5
I really like my Herculiner but if you are wanting colors get Durabak they are basically the same thing, except for the colors and some of the Durabak colors already have the UV in them
jsc7002 is offline
Best DIY tub liner joes1982CJ Jeep CJ Forum 3 01-23-2010 04:07 PM
raptor liner jcooley7 Jeep CJ Forum 2 10-18-2009 12:27 PM
scrambler bed liner is done!!! daltonw Jeep CJ Forum 19 10-15-2009 09:43 PM
liner 1976cj7 Jeep CJ Forum 6 04-14-2007 04:29 PM
Liner? Renegade578 Jeep CJ Forum 12 06-23-2002 08:44 AM
