What trany do I have??? - JeepForum.com
post #1 of 14 Old 04-24-2002, 05:04 AM Thread Starter
scottahicks
scottahicks's Avatar
Question What trany do I have???
I have a 1980 cj5 with the factory 304 and a 4 speed stick what transmission is this???
If its broke I can fix it. if it isnt broke give me a minute!!!
1980 CJ5, 304 V8, flat top pistons, rv cam, quadra-jet carb, edelbrock intake, hooker headers, Purple Hornies 3" header glasspacks, Solid Driveshaft, t-176 manual 4speed, 3" body lift, 1foot extended front bumper for wrecker winch "no winch yet" 33X12.5X15 Wild Country XRT's on chrome wagon wheels, custom spray paint job, lots of rust, dents, oh and a driver that treats it like a jeep "screw the paint I can make it!" Daily Driven!!!!! Green Jeep Club member #37 Flamed Jeep Club member #1 and President
scottahicks is offline
post #2 of 14 Old 04-24-2002, 11:12 AM
Hippo393
Exclamation
The secret may be hidden in your Jeep's serial number. Not sure, but research the digits on your VIN on <a href="http://www.specialtyparts.com/vins" target="_blank">www.specialtyparts.com/vins</a> and you might get lucky that way (and find out other cool info on your rig).
Hippo393 is offline
post #3 of 14 Old 04-24-2002, 01:06 PM
JIM79CJ7
JIM79CJ7's Avatar
Post
I believe it is a t-176
originally posted by Mikeythefireman :
Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there.
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff
2003 Inca Gold Rubicon , <------ Sissy jeep :)
JIM79CJ7 is offline
post #4 of 14 Old 04-24-2002, 01:51 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Post
Pretty good info to be found here - I agree with Jim, it's probably a T-176.
<a href="http://www.off-road.com/jeep/tech/trans/t176.html" target="_blank">Jeep transmissions</a>
Steve
OldJeepguy is offline
post #5 of 14 Old 04-24-2002, 07:03 PM Thread Starter
scottahicks
Post
if this is a t-176 does anyone know of an aftermarket shifter for this tranny one that might give it a shorter throw than stock???
post #6 of 14 Old 04-25-2002, 11:26 AM
GroundUpCJ7
Post
AMC was in the habit of putting the T176 behind its 304's, and the stock manual tranny behind the 304 in 1980 was a T176. So, I would guess that you do have a T176. I believe 4wd hardware has an aftermarket shifter that claims to reduce the throw on the shift, but let's face it, you're looking at a might long stick going through a pretty big arc. You can always cut the shifter off...
It's not so much a labor of love as it is shear determination.
GroundUpCJ7 is offline
post #7 of 14 Old 04-25-2002, 02:22 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
I agree it s a T-176. The other 4-Speed offered that year is the SR4 Ford Tranny, which was used standard behind the GM 151 4-banger, and (unfortunately) behind some of the 258's
The SR-junk, I mean SR4, you can easily tell, it is an aluminum case, and I believe it has some "fins" on the case. The T-176 is a cast iron case.
4wheeler4CJ is offline
post #8 of 14 Old 04-26-2002, 01:51 PM
KG4PAM
Post
sr-4 is definitely crap... i wish i had researched more and stayed away from it when i bought my 7. i had the reverse fixed 2 weeks ago and it pops out again... good thing the mechanic says he will "stand by" it...
'81 CJ-7 Got it when I was 16!
'06 Hummer H3, boulder gray, Adventure Package(electric rear locker and 70:1 crawl ratio BONE STOCK)
'71 Kaiser-Jeep M35A2 Deuce and a Half cargo truck, with winch. <for sale>
KG4PAM is offline
post #9 of 14 Old 04-26-2002, 04:07 PM
4wheeler4CJ
Arrow
That's not too big a deal that you got the SR4, KG4PAM, you have the Dana 300, and swapping a new tranny in is pretty easy, you may need your driveshafts retubed though. It could cost a little bit to do it, but I sold an SR4 on Ebay for $172, not including shipping, so you could sell yours and get some money back on it.
post #10 of 14 Old 04-27-2002, 05:46 PM
s4b1106
Post
4wheeler4CJ:
I am a little confused. I have what I have been told by the tranny shops around here is a T-176. The code off of the casting is what was used to identify it. It has an aluminum case. It is currently not in a 1980 CJ-5 with a Dana 300 transfer case. Not in it, 'cause I am fixing a whole buncha' stuff!
s4b1106 is offline
post #11 of 14 Old 04-28-2002, 04:37 AM
West
Post
Are you positive it's an aluminum case?
West is offline
post #12 of 14 Old 04-28-2002, 09:02 AM
4wheeler4CJ
Arrow
If it is definitely an aluminum case, then it is not a T-176, it is an SR4 or something else, like a T-4.
T-176 is a cast iron case, no bones about it.
It either has the wrong tag or was identified wrong.
post #13 of 14 Old 04-29-2002, 03:29 AM
s4b1106
Post
Yes, it is definately an aluminum case. And, the number is not just on the tag, it is cast into case as well. After I wrote the above post, I checked out the link for Jeep Transmissions that is listed towards the top of the list, and it shows the T-176 with the 2604203 casting number and says that it is an aluminum cased transmission. That seems consistent with what I have. Now to get it back inside of the Jeep, instead of sitting on the shop floor! Oddly, they don't seem to do much good on the shop floor, just take up space. Question, though. Is it worth changing the yolks on the dif from the strap type to the u-bolt type?
s4b1106 is offline
post #14 of 14 Old 04-29-2002, 08:49 AM
4wheeler4CJ
Arrow
I personally think it is worth it. I have seen many many strap yokes blow apart from hard driving, LOL. I have never seen a U-bolt blow apart, usually you will shatter the yoke before blowing apart the U-bolt. <img border="0" title="" alt="[Wink]" src="wink.gif" />
I'm gonna check a bit on that tranny. You peaked my interest a bit, LOL.
258 to a t-18 trany lionsfn Jeep CJ Forum 5 01-04-2010 05:44 PM
T18 Trany steveracer67 Jeep CJ Forum 7 12-09-2008 10:46 PM
looking for a overdrive trany rescuetech Jeep CJ Forum 8 06-01-2008 07:53 PM
Auto Trany Help 82cj7401 Jeep CJ Forum 6 10-30-2007 05:36 AM
What type trany do I need w/ a 258 on an '84 CJ? ed4 Jeep CJ Forum 6 03-08-2007 08:09 PM
