What transmission to go with on 85cj7? - JeepForum.com
post #1 of 6 Old 10-06-2003, 10:23 AM Thread Starter
jeepin cj-5
Well i have a 5 speed transmission in my 85 cj7 (i think t5?)right now but something went on it. I have a 83 parts jeep with a 4 speed transmission right now but im not sure which one to go with. Should I fix the 5 spd or replace i with the 4 spd? Wil the 4 spd go the same speed on the highway?
jeepin cj-5 is offline
post #2 of 6 Old 10-06-2003, 10:37 AM
jadams68
jadams68's Avatar
Well considering these other factors:
a) You have a T-5 and they are inherently week trannies.
b) You have a free 4 speed, but you didn't indicate what kind.
c) A "fix" of a T-5 should really be a complete transimission rebuild because it's cost efficient in the long run.
I 'd say this:
If the 4 speed is a T-176 and not an T-4, I'd do the swap. You will achieve the same highways speeds, but without the 5th gear overdrive, you would probably suffer a 5-10mph hit. Big deal.
One note. If you regeared your differentials lower than stock (2.73, 3.31, 3.54) to something like (4.10,4.56), you will definitely suffer on the highway.
If the donor is a T-4, I would go for the T-5 rebuild unless you had other options in mind.
IF it's a T-176, it's a no brainer...go for it.
Hope this helps.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 6 Old 10-06-2003, 11:39 AM
wm69
I agree, and you can tell what extra tranny you have by looking at the stick. Straight stick=t176=good.... Curved stick=t4/sr4=bad . I have a T176 in one of CJ's, and a T5 in the other. I like the 4 speed a LOT more. It will go the same speeds on the highway, but the gas milage isn't quite as good (if you've got a jeep as a highway vehicle/ good gas milage you need to seek professional help). Best thing about the 4 speed is that when I'm going up and down hills, the 5th gear is worthless, and i'm constantly downshifting to 4th, then upshifting. I live in the Ozarks, so that turns into a lot of shifting. The 4 speed will pull just fine, and the 4 speed gets better milage at highway speeds than the 5 speed gets when I'm unable to use 5th gear (when I have to leave the 5 speed in 4th gear). If you live in flat lands, and the 4 speed has a curved shifter, get the T5 fixed, otherwise I would put the 4 speed in. Another benefit of the T5 is the ultra low 1st gear, so take that into consideration too. I personally think the 4 speed in 1st hear/ 4 low is lower than I'll ever need.
wm69 is offline
post #4 of 6 Old 10-06-2003, 11:39 PM
Sandman74
NV4500 If you dont know, ask someone
Youth and talent is no replacement for age and treachery.
Sandman74 is offline
post #5 of 6 Old 10-07-2003, 06:16 AM
jadams68
jadams68's Avatar
See, you had to throw that in didn't ya?
I agree, if you have the cash, get yourself an NV4500 out of a Dodge Pickup....tack on the adapters...the new driveshaft....the relocation of the the skid plate....and you're set.
jadams68 is offline
post #6 of 6 Old 10-08-2003, 09:20 PM Thread Starter
jeepin cj-5
How much would a rebuilt t5 cost? how much are they new? The reason is because my t5 not is real messed up, i figure 300+ in gears and bearings. what should i do... i have talked to alot of people and the fact that the t-5 does have the over drive will help when i regear so i was planning on sticking with it.
Would a 93 Wrangler Hard Top fit a 85CJ7? northam Jeep CJ Forum 1 12-30-2009 12:44 PM
85CJ7 T4 Tranny Upgrade? rdaviscj7 Jeep CJ Forum 6 06-15-2009 07:31 AM
85cj7, 4.0, straight 6, transmission fluid? green11 Jeep CJ Forum 10 03-14-2009 01:21 PM
planning lt1 4l60e swapp into 85cj7 chrisdoc Jeep CJ Forum 8 02-28-2009 12:03 PM
85cj7 Danos85CJ7 Jeep CJ Forum 2 02-25-2007 01:08 PM
