what transmission is this? - JeepForum.com
post #1 of 15 Old 07-29-2011, 02:48 PM Thread Starter
swarren
It says borg warner on the side but not sure what transmission it is can anybody tell me. It is in a 1985 cj7 with a 258 i6 motor
swarren is offline
post #2 of 15 Old 07-29-2011, 02:50 PM
CoryA
Probably a t4 or t5 is it 4 or 5 speed?
CoryA is offline
post #3 of 15 Old 07-29-2011, 03:00 PM
ctrim78
It's a T5, T4's were on 4 cyl engines.
ctrim78 is offline
post #4 of 15 Old 07-29-2011, 03:01 PM Thread Starter
swarren
5 speed. Is there an easy way to tell what it is?
swarren is offline
post #5 of 15 Old 07-29-2011, 03:03 PM
John Strenk
John Strenk's Avatar
1976 CJ5
They only had one 5 speed. The T5
John Strenk is offline
post #6 of 15 Old 07-29-2011, 03:05 PM
CoryA
No t4 came with 6cly and 4cly
CoryA is offline
post #7 of 15 Old 07-29-2011, 03:08 PM Thread Starter
swarren
lol I am getting confused
swarren is offline
post #8 of 15 Old 07-29-2011, 03:12 PM
CoryA
Don't be it's a t5 bud
CoryA is offline
post #9 of 15 Old 07-29-2011, 03:18 PM Thread Starter
swarren
i hope so Cause I am trying to change my clutch from a linkage to hydraulic and needed to know what type of tranny it is
swarren is offline
post #10 of 15 Old 07-29-2011, 03:31 PM
248107
Guest
1983 CJ7
I have a 83 258 with a 4 speed.Did tranny styles change after 83
248107 is offline
post #11 of 15 Old 07-29-2011, 03:51 PM
CoryA
After 82 they changed to the t4 n t5 81-82 they used the sr4 a 4 speed ford tranny with reverse up by first. Be careful though people swap trannys all the time you don't Always have the transmission your jeep came with but in the case of his 5 speed its pretty clear that it is a t5
CoryA is offline
post #12 of 15 Old 07-29-2011, 04:28 PM
jeepwhore
Don't forget about the T176 4 speed. I haven't found any source that gives clear cut transition years between the various 4 speeds used. It seems like between 80 and 86 any one of the three could have come in a CJ depending on the engine and options the Jeep was ordered with.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #13 of 15 Old 07-29-2011, 04:38 PM
CoryA
Good point even Novak says the transmission years "respectively"
CoryA is offline
post #14 of 15 Old 07-29-2011, 04:50 PM
248107
Guest
1983 CJ7
So if you know dimensions,shift pattern and pictures you can identify it.I always thought i had a S4 instead of T4
Don't mean to hijack your thread
248107 is offline
post #15 of 15 Old 07-29-2011, 05:14 PM Thread Starter
swarren
Its ok if anybody else needs help to id their tranny is fine with me. Thanks for the helpguys
swarren is offline
Transmission Id? Cpolinsky Jeep CJ Forum 5 10-26-2009 01:32 AM
help with transmission islander86 Jeep CJ Forum 12 10-14-2009 06:34 PM
transmission ? zj333 Jeep CJ Forum 7 06-15-2006 07:58 AM
T5 Transmission Hank86 Jeep CJ Forum 11 11-08-2004 04:31 PM
Which transmission JERSEYJOE Jeep CJ Forum 1 10-06-2004 12:50 PM
