What trans would this CJ-7 have? - JeepForum.com
post #1 of 7 Old 03-18-2002, 12:40 PM Thread Starter
mud4me
Post What trans would this CJ-7 have?
I was looking at a house for sale yesterday and I noticed the owner had a beat up CJ-7 sitting in the woods.
It was raining so I didn't walk over to it. Its a 1980 CJ-7. I asked the owner what trans it had, he said 4 speed, and that the first gear was not a creeper gear, and he didn't know what model trans it was.
He said if I buy the place the Jeep is mine! I plan to go back and crawl under the Jeep to see what trans it is, or to get the numbers off the casing.
Anyone have any knowledge or guesses what 4 speed trans came in a 1980 CJ-7???
86 CJ-7, 360, Holley Avenger, T-18, Dana 20, 4" suspension,
mud4me is offline
post #2 of 7 Old 03-18-2002, 01:25 PM
Bulletproofcj7
Post
T-176, T-177 1980-86. SR-4 1980-81.
T-4 1982-86
I just looked this up in my 4wd hardware catalog, they have exploded view pictures you can compare to the one in the jeep.
hope this helps!
jason
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #3 of 7 Old 03-18-2002, 01:55 PM
boredstiff
Post
probably a T4 or a T150...
T-176 and T-18's have pretty low first gears...
boredstiff is offline
post #4 of 7 Old 03-18-2002, 04:01 PM Thread Starter
mud4me
Post
My guess was T4 or T150.
Are either one of those trans any good for highway and trail riding use? Will either one hold up behind a 360?
I still think I would rather have a T18 over the T4. Seems as if many folks have the T150s.
mud4me is offline
post #5 of 7 Old 03-18-2002, 04:50 PM
Steelhead
Post
If it happens to be the T-176 it will probably hold up to a 360 because it was available behind the 304.
Steelhead is offline
post #6 of 7 Old 03-18-2002, 10:55 PM
only in a jeep cj
Post
hey "mud 4 me",
Heres a simple way to check......sit in the Jeep and try to shift into reverse. If you'r able to push down and the shifter will then go towards the upper left, you have an SR-4. If it has a "normal" shift pattern, with a straight shifter, it's a T176, with a curved shifter, a T-4.......Good luck on the house hunting.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #7 of 7 Old 03-19-2002, 08:59 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Post
It's not a T-150, that is a 3 speed. It is either a T-176 or SR-4 if it is stock. Otherwise, it is a T-4. It is definitely not the T-18 of your first gear isn't low. Is the jeep a 4-banger? If so, it is the SR-4 tranny, although the SR-4 was also used behind some 258's.
SR-4 barely will hold up to a 6, so don't even bother trying to use that. T-176 will hold up to a 360 as long as you don't go nuts, I personally wouldn't use a T-4 behind a 360, but it won't be that tranny unless it was swapped in at some point (wrong year).
T-18A or T-18 is the best choice behind the 360, but they are costly (although I did see a T-18/Dana 20 go on Ebay for only $355 last week, the guy stole it).
4wheeler4CJ is offline
79 CJ7 3 spd trans tmsadillard Jeep CJ Forum 3 09-09-2006 01:25 AM
Trans mojotomred Jeep CJ Forum 0 10-01-2004 08:30 AM
trans thenubsterman Jeep CJ Forum 2 09-23-2004 08:06 PM
304 with a T5 trans sinman Jeep CJ Forum 2 12-10-2003 06:10 PM
