What trailers are you all using? - JeepForum.com
post #1 of 45 Old 11-27-2012, 05:36 PM Thread Starter
Keith
Admin
Keith's Avatar
I found a 16' tandem axle with 5400lb capacity.
I think a stock is right around 3000lbs; winch, roll cage, bumpers, spare, coolers, etc. Add up fast or would 5400 suffice?
- Advertisement Free Jeep Forum
Keith is offline
post #2 of 45 Old 11-27-2012, 05:41 PM
85LaredoCJ7
I have a 7k GVW, 16' bed, car hauler. I use 10 ply E rated tires, dual axle with brakes on rear axle. Got any pics of it??
The Dude abides....
85LaredoCJ7 is offline
post #3 of 45 Old 11-27-2012, 06:00 PM
robert1973
1977 CJ7
Id be more than willing to bet you'll be just fine. My buddies rig on one tons with 44s and a sbf engine with 1/4 inch plate everywhere on the tub, and I mean a lot of steel, he's tipping the scales a little over 5100 lbs. My rig on waggy 44s and 33s with fiberglass tub and hood loaded with winch, highlift and all the other trail goodies I figure I'm prob around 3800-4000lbs. My trailer is also rated for 5900 lbs and pulls just perfect.
ΜΟΛΩΝ ΛΑΒΕ
The Right is wrong and the Left is stupid
robert1973 is offline
post #4 of 45 Old 11-27-2012, 08:07 PM
roadhog304
1973 CJ5
Personally i would not buy anything less than a trailer with dual 3500# axles (7,000# total weight rating). A trailer is a lot like a welder, you need to buy more than you think you will need. My trailer is an 18', 7,500 lb rated, but only has one brake axle. The one brake axle does fine but many areas by law you are required to have all axles have brakes so if i ever upgrade i will make sure to have dual brakes. mine also has a wood floor but the next one will be steel. Wood would be okay for just a jeep but all of the other crap i haul sometimes is pretty hard on the wood floor.
1973 Jeep CJ5 Amc powered resto-mod
1976 Jeep CJ7 GM powered future 1 ton crawler
roadhog304 is offline
post #5 of 45 Old 11-27-2012, 08:15 PM
82JeepCJ7
1982 CJ7
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #6 of 45 Old 11-27-2012, 08:48 PM
CSP
x2 on the suggestion of at least tandem 3500 lb axles. I have a trailer of this size and constantly wish I had gone to 5k axles. I have a 14k gooseneck flatbed, but there are times when it's just too big or already has something on it, so I use the smaller one (my little one has an 18' deck).
CSP is offline
post #7 of 45 Old 11-27-2012, 10:46 PM
lucdog
lucdog's Avatar
1980 CJ5
5400 pounds would be about correct for a trailer with two #3500 axles. The unsprung weight would then be around 1600#, for a total of 7000 GVW.
Mine is a 18', I'm glad I didn't go with the 16', I can haul my Jeep and still have room for my ATV or motorcycle. Plus a mid sized truck cross tool box mounted in the front.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 45 Old 11-27-2012, 10:57 PM
John N
1981 CJ8
You should be fine. My Scrambler weighs in at about 4100 lbs. Load your Jeep up with everything you'd normally take and go get it weighed. You'll probably be good at that rating, but you don't want to be maxed out or close to it.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #9 of 45 Old 11-28-2012, 07:10 AM
Jack61
1981 CJ7
I built this one a few years ago. Axles rated at 6k lbs each but found out that with a hub upgrade the rating would go up to 7k lbs. The only other thing I might do is add brakes to the second axle especially since a lot of my towing is in steep mountain terrain.
It used to be, God bless America, it has become God help America
Jack61 is offline
post #10 of 45 Old 11-28-2012, 07:28 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Probably be okay.. I have a trailer that specs out similarly. I used to haul my 5000lb buggy (and a bunch of spare parts) on it.
The telltale signs to watch out for.. wear on the inner part of the tires= bent axles.
BESRK is offline
post #11 of 45 Old 11-28-2012, 09:23 AM
CSP
So reading the responses, one thing is unclear. Is the total capacity of this trailer 5400 pounds, or is that payload capacity (not including the weight of the trailer)?
CSP is offline
post #12 of 45 Old 11-28-2012, 10:01 AM Thread Starter
Keith
Admin
Keith's Avatar
5400 is the payload capacity. Both axles are 3500lbs, then trailer is roughly 1600.
Keith is offline
post #13 of 45 Old 11-29-2012, 05:40 AM
cjjon7
1983 CJ7
Yep no such thing as 2700 lb axles. ..that I've seen..
cjjon7 is offline
post #14 of 45 Old 11-29-2012, 08:38 AM
CSP
There are all kinds of oddball axles out there, especially when it comes to older trailers. Homebuilts with mobile home axles are another type that you never can tell what they are rated for.
CSP is offline
post #15 of 45 Old 11-29-2012, 08:18 PM
roadhog304
1973 CJ5
Since it has 3500 lb axles you should be just fine. I would go for it.
