What is thing for? Needing to know if I can remove with my 4.0 head and MPFI setup. - JeepForum.com
post #1 of 4 Old 08-06-2013, 09:38 PM Thread Starter
JeepScrambler
1985 CJ8
I am in the process of installing a 4.0 head with the MPFI intake and exhaust on my '85 CJ7. Currently I am weeding through the wiring and thinning it out. This is on the stock '85 CJ engine side harness and was curious as to what this piece is for?
There appears to be some sort of diodes inside but I haven't pulled it apart any further to look:
It comes off of this much larger weather-pack connection:
I will be using the stock CJ style starting and charging system, along with the CJ style A/C. Basically I am needing to know if all this can be removed and still allow me to use these two systems with my 4.0 head and MPFI. Anyone familiar with this part and what function it serves?
1985 CJ8, '85 CJ8, '85 CJ7, '84 CJ7, '84 CJ8, 2-'84 CJ8 AK Postal Scramblers, '82 CJ8, '82 CJ8, '82 CJ8, '53 CJ3A
'02 Dodge Ram 2500 4x4 Cummins HO 6 spd
'05 Wrangler Unlimited Rubicon Sahara Edition (0002 of 1000), 6 spd, hard top, stock, 38K miles
'06 Grand Cherokee "Overland"
JeepScrambler is offline
post #2 of 4 Old 08-07-2013, 04:19 AM
CJ7VFR
You don't want to get rid of that. It's the connection to your Flux-Capacitor....
CJ7VFR is offline
post #3 of 4 Old 08-07-2013, 04:20 AM
John Strenk
John Strenk's Avatar
1976 CJ5
It's a bunch of diodes used to sense it the Intake heater, AC and something else. It's used to activate the solvac solenoid on the BBD to kick up the engine speed at idle.
Not needed if you don't have the OEM computer operating anymore.
Look for Diode Array in this schematic. Lower right. Just above the blue box
John Strenk is offline
post #4 of 4 Old 08-07-2013, 07:12 AM Thread Starter
JeepScrambler
1985 CJ8
Might as well remove it, I don't the Jeep can do 88 mph anyways!
Thank you very much John, that is exactly what I was needing to know! Just wanted to double check and make sure it wasn't necessary for my AC to operate before I take it out. Thanks again for the help!
