what are these holes on the back of my Clutch Housing Flange??? - JeepForum.com
post #1 of 6 Old 01-27-2010, 01:18 PM Thread Starter
77texascj7
1977 CJ7
Anyone know whate these holes are for...noticed them after a tranny swap. one hole visible in this picture on the left side of the clutch housing flange and 2 i think on the right side
77texascj7 is offline
post #2 of 6 Old 01-27-2010, 01:31 PM
keith460
Jeep. There's Only One
keith460's Avatar
Different model transmission mounting holes.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 6 Old 01-27-2010, 01:33 PM Thread Starter
77texascj7
1977 CJ7
Do i need to cover them.... seems like mud and water going through there onto the clutch plate wouldn't be good.
post #4 of 6 Old 01-27-2010, 04:28 PM
keith460
keith460's Avatar
Water would find its way in there even if you covered it up or put a bolt in place. I doubt any mud could be slung into the hole and there are also entry points through the fork lever rubber boot too that water and or mud could enter.
1984 CJ-7 Renegade
keith460 is offline
post #5 of 6 Old 01-27-2010, 09:20 PM
lucdog
lucdog's Avatar
1980 CJ5
What kind of tranny do you have? x2 on the holes for different trannys. I would put some plastic plugs in if they can be found. Just to make cleaning esier if you change trannys in the future.
bill
lucdog is offline
post #6 of 6 Old 01-28-2010, 06:29 AM Thread Starter
77texascj7
1977 CJ7
Thanks for the input. T-150 transmission. i
ve got a new fork lever boot to put on, mine was torn.
it just seems odd that those holes are exposed... plus the entire (even the exposed part) of the clutch housing flange was real shiny...like it had never been exposed to elements.... don't remember taking off any cover or plate though. Maybe i just don't remember steel brushing the whole flange.
I go through pretty deep mud and water in this jeep(see profile picture) so wanted to make sure.
on an unrelated side note- when i drained the transmission fluid from the old transmission... there were two fluids in there. one was black (the gear oil) and the other half of the fluid was a watery brown...i'm guessing mud. must have come in through the breather valve. i should probably follow that waterproofing thread on here.
plate between clutch housing & Transmission 77texascj7 Jeep CJ Forum 1 12-02-2009 08:33 AM
hydraulic clutch alingment issues on bell housing - T18 swap certifiablejeep Jeep CJ Forum 2 03-14-2008 07:23 AM
clutch and bell housing compatibility questions outdoordad@comc Jeep CJ Forum 2 12-19-2005 06:47 AM
Does a clutch have a front and back? jmerlick Jeep CJ Forum 13 11-22-2004 08:30 PM
HELP Clutch arm hanging up on header flange junglejeep Jeep CJ Forum 4 03-09-2004 03:52 PM
