What are these engine parts ? - JeepForum.com
post #1 of 15 Old 05-08-2013, 12:24 PM Thread Starter
DoubleDown
1983 CJ7
The "bell" shaped part is on the passenger side near the back of the engine. What is it and what does it do ?
The second is on the drivers side and is screwed into the intake manifold. It looks like two wires were cut off of it. I just don't know what these parts are.
The CJ is nuttered and runs ok if it's not too cold out.
DoubleDown is offline
post #2 of 15 Old 05-08-2013, 12:28 PM
gosupes
Top pic is an oil pressure sender for a gauge. The bottom pic looks like a temp switch/sender.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #3 of 15 Old 05-08-2013, 12:38 PM Thread Starter
DoubleDown
1983 CJ7
Do you think the wires that were cut form the temperature sender went to the computer ?
post #4 of 15 Old 05-08-2013, 12:53 PM
M20Keeper
1982 CJ7
I don't think the 83 had a computer did it? I thought they came into the Jeep in 85. I'm sure it had something to do with emissions though.
M20Keeper is offline
post #5 of 15 Old 05-08-2013, 01:21 PM
keith460
Jeep. There's Only One
keith460's Avatar
Yes, that would be the one that sent temperature info to the MCU.
1984 CJ-7 Renegade
keith460 is offline
post #6 of 15 Old 05-08-2013, 01:32 PM
walkerhoundvm
1981 CJ8
Seconded. I've just spent the past week learning all about this system. No computer, no need for that to be connected. But you should have a computer on an '83...which doesn't matter if you've been nutter'd.
There should also be a temperature switch under the rear hose on the manifold, with a single post. That one serves as a ground for the manifold heater relay. With poor engine performance in the cold, before the engine warms up, I'd be suspicious you haven't got that in working order, either.
walkerhoundvm is offline
post #7 of 15 Old 05-09-2013, 09:04 PM Thread Starter
DoubleDown
1983 CJ7
Thanks, I'll look into that.
'83 was the first year the CJ got a computer, after the bypass was done I removed all the unnecessary wiring and that is when I noticed the other things. I'm still trying to get a grasp on everything one step at a time. It's been a fun journey and so far so good.
Thanx as always to all that replied
post #8 of 15 Old 05-10-2013, 02:41 AM
John Strenk
John Strenk's Avatar
1976 CJ5
This is for an 85 but should be similar to what you have.
http://home.sprynet.com/~dale02/
Also on the top photo is an oil pressure SWITCH that also controls the manifold heater and the e-choke.
If the MCU harness is gone, you may have lost the connections for these things.
John Strenk is offline
post #9 of 15 Old 01-09-2014, 06:58 PM Thread Starter
DoubleDown
1983 CJ7
So, I checked out the site and need to reconnect the e-choke wires to the oil pressure switch, but the wires are gone.
How can I reconnect them ? Should I go to a junk yard and take the wires, I guess all u really need is the connectors.
Any suggestions ?
post #10 of 15 Old 01-09-2014, 08:22 PM
SouthernGypsy
De Oppresso Liber
SouthernGypsy's Avatar
The PO must have done your nutter incorrectly, or did more than just the nutter because you still have those wires left after a simple Nutter by-Pass. It doesn't remove those.
~ SouthernGypsy's Jeeps ~
2004 Jeep TJ Rubicon 4.0L/Automatic
1983 Jeep CJ-7 Limited 4.2L/5 Speed
SouthernGypsy is online now
post #11 of 15 Old 01-09-2014, 09:14 PM Thread Starter
DoubleDown
1983 CJ7
So, my question is how to replace them ?
If I get the connector for the choke where do I run it to ? The oil pressure switch I think, but where do I connect it ?
post #12 of 15 Old 01-09-2014, 09:26 PM
keith460
keith460's Avatar
Not the Oil Pressure "Sender" that you are calling an oil pressure switch. The actual device is called an Electric Choke Switch and it is screwed into the same union as the Oil Pressure Sending Unit.
The Electric Choke Switch sends power to the Manifold Heater Relay AND the Choke Heater at the same time. All you need to do is splice into the Electric Choke Switch which will have power to it anytime the key is on. It will close when oil pressure is present and send that power to the Electric Choke AND Manifold Heater Relay.
1984 CJ-7 Renegade
keith460 is offline
post #13 of 15 Old 01-09-2014, 10:55 PM
BagusJeep
1981 CJ7
If you dig out a wiring diagram you will find the ECS is fed by a Red wire that is live in ACCY and Run. Look in that wiring loom along the bulkhead for a Red wire as it feeds several things in the engine bay from the fuse box down a red wire.
The Manifold heater is fed by a relay. The control side comes from the ECS. The power for the heater itself comes from a splice into the large red wire that runs from the solenoid up to the bulkhead and eventually feeds the fuse box.
You therefore need to locate the Manifold Heater Relay and check how it is wired.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #14 of 15 Old 01-10-2014, 03:07 AM
John Strenk
1976 CJ5
I think this discussion is also going on in another post. shall I combine them?
post #15 of 15 Old 01-10-2014, 04:05 AM
keith460
keith460's Avatar
I would since the OP was only asking what the parts were and is now posting with another forum member on how to wire them.
1984 CJ-7 Renegade
keith460 is offline
