What is the strongest clear coat you can roll on the roll bar over fresh paint? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > What is the strongest clear coat you can roll on the roll bar over fresh paint?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff XJ Unirail Channel Reinforcement....The Original 3/8" Ruffstuff Diff Cover!
Unread 12-10-2009, 04:00 PM   #1
HHICJ7
I ordered some "Spray Max 2k" that is a STRONG 2 part clear coat in a rattle can. However, after reading all the labels and warnings about "you get a breath of it you die" I think I will pass on using it. I would REALLY rather have somthing that is STRONG that I can roll on instead of spray. Any ideas?
Thanks!
HHICJ7 is offline   Reply With Quote
Unread 12-10-2009, 04:24 PM   #2
Coiz
Coiz's Avatar
1979 CJ7
No help on the roll on. Why not just wear a respirator? All paints have that warning to some extent. It's a SYA type of disclaimer and intended to keep huffers from trying the stuff.
Mike
My build thread
Coiz is offline   Reply With Quote
Unread 12-10-2009, 04:27 PM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Use a fan.... and stay upwind...
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
