what size tire under RE 4.5" lift???? - JeepForum.com
post #1 of 13 Old 08-29-2011, 08:41 AM Thread Starter
Gasman303
1979 CJ7
What size tire are some of you running under your cj7's! I'm thinking of going with the re 4.5" suspension lift and try to run 35" tires, also I'm considering buying some 1983+ cj wide axles! I don't want to have to install a body lift if at all possible!! I have a 1979 jeep cj7, thanks
Gasman303 is offline
post #2 of 13 Old 08-29-2011, 08:52 AM
YeloCJ
Body lift
You'll still need at least a 1" body lift, even then, the tires will rub a little, at full compression.
YeloCJ, 360, 36's and Detroits f/r, T-18, Tera-low 20
YeloCJ is offline
post #3 of 13 Old 08-29-2011, 09:09 AM
Jeepican
1976 CJ5
I thought RE went out of business?... i guess u can get lucky and find a kit somewhere.....
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #4 of 13 Old 08-29-2011, 09:23 AM Thread Starter
Gasman303
1979 CJ7
I figured! Since I'll be using yj springs do you think its a good idea to use boomerange shackles?
post #5 of 13 Old 08-29-2011, 10:13 AM
danturner266
1983 CJ7
I believe RE is back, Quadratec recently released that information on their web site.
danturner266 is offline
post #6 of 13 Old 08-29-2011, 10:55 AM Thread Starter
Gasman303
1979 CJ7
I'm glad they're back!
post #7 of 13 Old 08-29-2011, 12:41 PM
gojeepin
1983 CJ7
You'll need to trim the rear of the wheel opening on your tub or 35s will hit the back when compressed.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #8 of 13 Old 08-29-2011, 01:43 PM Thread Starter
Gasman303
1979 CJ7
With a 1" body lift?
post #9 of 13 Old 08-29-2011, 01:53 PM
WoodyHD
1983 CJ7
I tried ordering the kit from morris a week ago and they were on back order until indefinite date. RE has been waiting on springs from what he told me. Didn't try any other dealers, but I called RE and guy said they would be shipping out the kits next month or sooner.
WoodyHD is offline
post #10 of 13 Old 08-29-2011, 01:58 PM
mtbtweety
mtbtweety's Avatar
1982 CJ8
I have 35s on my CJ8 with a 4.5" RE and no BL. It would likely rub at full articulation, but I haven't found out yet...
mtbtweety is offline
post #11 of 13 Old 08-29-2011, 02:11 PM
gojeepin
1983 CJ7
Yes, that's with a 1" body lift.
The problem isn't height in the rear. The tire may barely fit if it went straight up... but the rear axle goes up and to the rear as the spring flattens.
gojeepin is offline
post #12 of 13 Old 08-29-2011, 07:21 PM Thread Starter
Gasman303
1979 CJ7
Nice jeeps guys!! Hey gojeepin do you have a body lift and are those FW axles or NW?
post #13 of 13 Old 08-29-2011, 08:08 PM
MoC
36's 4.5" RE and 1" Daystar Body. Will rub if it flex to much.
MoC is offline
Which tire size (and tire) for CJ-7 with 2.5" BDS lift? danattherock Jeep CJ Forum 22 05-10-2013 06:51 PM
lift and tire size help!!! OleBlueCJ7 Jeep CJ Forum 13 05-13-2011 10:32 AM
Max Tire Size - 84 CJ7 w/ 3" Lift cpistorius Jeep CJ Forum 12 03-14-2011 06:07 PM
Need Advice, lift, no lift, tire size, wheel spacers??? darwood112 Jeep CJ Forum 3 03-25-2009 12:55 PM
Post your lift size, tire size, necessary modifications, etc. Hillbillyd Jeep CJ Forum 7 06-06-2004 09:38 PM
