What Size Plug/Bolt goes in here??? - JeepForum.com
post #1 of 5 Old 09-13-2010, 07:37 PM Thread Starter
renegade82us
Hi I have a question I'm hoping someone can answer. I am trying to find a plug or bolt to plug the circled hole. It seems to be a weird size, I cant seem to find any thing close. I think its a 1/2 bolt but I am not sure.
Its a 1982 CJ7 with the straight 6.
Also, if i have to replace the whole part since the bolt cant be found, what part do i need? I cant find it in the Chilton Manual.
Thanks!!
renegade82us is offline
post #2 of 5 Old 09-14-2010, 03:17 PM
tommybio
1978 CJ7
Air Distribution Manifold
Renegade,
I believe the holes were created when you removed the air distribution manifold - correct?
I asked a similar question and the response I received was to look for NTP threaded PLUGS. Usually have a square head like plumbing hardware. I found them at Home Depot and Lowes. I had to torque them in place a bit, but it worked. And I used some high temp sealant, as well. Best not to let these leak.
I had similar issues and posted a thread awhile back:
http://www.jeepforum.com/forum/f8/ca...ifold-1076048/
'78 CJ7 258 w/ manual tranny
31X15 Wrangler Duratracs w/ Pro Comp wheels
2 1/2" Pro Comp suspension lift and Pro Comp steering stabilizer
Swapped Carter 1bb for an MC2100 and TeamRushed !
tommybio is offline
post #3 of 5 Old 09-14-2010, 07:57 PM
yahwhy
1982 CJ7
npt, national pipe thread, just like tommybio said lowes/home depot ,plumbers palace, and the like
yahwhy is offline
post #4 of 5 Old 09-14-2010, 10:32 PM
Drednot
They are 1/4"NPT if I remember correctly.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #5 of 5 Old 09-15-2010, 10:05 AM Thread Starter
renegade82us
Originally Posted by tommybio View Post
Renegade,
I'm not sure how the holes were created, the engine was rebuilt by the previous owner. There are a lot of smog and other parts missing from this engine, which makes it very interesting to work on.
I will pass by Home Depot on the way home from work today.
Thanks for your reply!
bolt , exhaust , plug , size
what is this plate with a bolt & nut where the freeze plug should be? 1984Laredo Jeep CJ Forum 4 08-01-2010 11:53 AM
Need help with bolt head size, strap bolt u-joints neals80 Jeep CJ Forum 6 04-13-2010 11:05 AM
need bolt size for v8 motor mount bolt to frame rcgkaw Jeep CJ Forum 3 08-25-2009 09:16 PM
T-5 pivot bolt used instead of tranny fill plug........ sgt jeep Jeep CJ Forum 6 03-05-2009 05:01 PM
Fill Plug size?? A Bryan Jeep CJ Forum 2 10-12-2007 09:14 AM
