What size driveshafts? - JeepForum.com
post #1 of 12 Old 06-21-2013, 09:42 PM Thread Starter
JMcDonaldKnives
1980 CJ7
Anyone know what size driveshafts I'm going to need for my CJ7? 4" BDS lift, AMC258 and T177 with Dana 300 and stock axles. Going to run 33s.
Director of Texas Jeeps Corpus Christi Chapter
My Build Threads
1980 CJ7 4.2L T177 D300 D30 AMC20 (under construction)
1989 YJ 4.2L T177 NP231 D30 D35 Pro Comp 3" lift 32/1150/15 BFG AT
JMcDonaldKnives is offline
post #2 of 12 Old 06-22-2013, 01:34 AM
Spieg8
1984 CJ8
Could probably take a ballpark guess, but I won't. A 4" lift on a CJ7 is probably going to require a T-case drop and CV driveshaft as well as some degree shims (unless you rotate the perch mounts). It's probably best to get the suspension in and the drive line angles set where they should be and then measure for the driveshaft(s) before having them made. Measure yoke center to yoke center with the suspension at a static level position, at full extension (jack up the frame so wheels are off the ground and axles are hanging only by the springs), and compressed if you can (ask a dozen friends to climb on, or I can give you contact info for my ex-wife LOL). Give the measurements to the drive shaft shop in order to get the proper length. Depending on your setup you may need long travel slip yokes (are you planning to use shackle reverse kit?). Another thing you want to decide is the diameter and thickness of the tube you need...
Spieg8 is offline
post #3 of 12 Old 06-22-2013, 04:38 AM
gojeepin
1983 CJ7
I agree with Spieg8. You need to measure... your distance and your angles. While I don't cover the length measurement, you can read about all the other aspects of a lift in the article linked in my signature block.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #4 of 12 Old 06-22-2013, 08:19 AM
CSP
I disagree with the bit about a transfer case drop. That's a band-aid for keeping the stock driveshafts. If you're getting new shafts leave the transfer case alone and get a CV type rear driveshaft, which will handle the steeper angle in the rear.
CSP is offline
post #5 of 12 Old 06-22-2013, 09:55 AM
capt205
1983 CJ7
Just did the 4.5 RE lift. I went with the double carden shafts. I can measure them tomorrow. I did not use the transfer case drop that came with the kit.
capt205 is offline
post #6 of 12 Old 06-22-2013, 10:31 AM Thread Starter
JMcDonaldKnives
1980 CJ7
That would be great. Your measurements should be just about the same for mine. Are you running the same engine/trans combo that I am?
My Build Threads
post #7 of 12 Old 06-22-2013, 03:10 PM
capt205
1983 CJ7
Yes I am...258, T176, D300, D30 front, and D44 rear.
I'm at the station today, so I'll post up the measurement tomorrow.
capt205 is offline
post #8 of 12 Old 06-22-2013, 06:13 PM Thread Starter
JMcDonaldKnives
1980 CJ7
Is there much difference between the driveshaft with a D44 compared to AMC20?
My Build Threads
post #9 of 12 Old 06-23-2013, 10:56 AM
Cutlass327
1978 CJ5
Not much if any that I found. I just swapped from the 20 to the 44 and using the same driveshaft, although I didn't set the angles right (yet) so I don't know for definite if the shaft length is different. It works, but vibrates from the angle issues.
Don't guess. His measurement will be a good starting point, but don't have yours made until the lift is on and the angles are set. You only want to spend that money once, and shortening is a lot cheaper than lengthening if you got it wrong.
Rick
Cutlass327 is offline
post #10 of 12 Old 06-23-2013, 02:41 PM
Spieg8
1984 CJ8
If I remember correctly (it's been quite a while), the yoke on the Dana 44 sits about an inch or so more forward than a Model 20 (slightly shorter driveshaft). They can use the same Spicer 1310 U-joint (some people like to upgrade to a beefier model).
Spieg8 is offline
post #11 of 12 Old 06-23-2013, 04:06 PM
capt205
1983 CJ7
Mine are as follows:
measurements are center of u-joint to center or u-joint
Front 31.5"
Rear 26"
Double Carden's on both
capt205 is offline
post #12 of 12 Old 06-23-2013, 04:27 PM Thread Starter
JMcDonaldKnives
1980 CJ7
Front 31.5"
Rear 26"
so a 27" should be just about perfect for mine in the rear and a 31" in the front. Thanks. But I will double check before I order anything.
My Build Threads
