-   -   What size driveshafts? (http://www.jeepforum.com/forum/f8/what-size-driveshafts-1539683/)
JMcDonaldKnives 06-21-2013 10:42 PM
Anyone know what size driveshafts I'm going to need for my CJ7? 4" BDS lift, AMC258 and T177 with Dana 300 and stock axles. Going to run 33s.
Spieg8 06-22-2013 02:34 AM
Could probably take a ballpark guess, but I won't. A 4" lift on a CJ7 is probably going to require a T-case drop and CV driveshaft as well as some degree shims (unless you rotate the perch mounts). It's probably best to get the suspension in and the drive line angles set where they should be and then measure for the driveshaft(s) before having them made. Measure yoke center to yoke center with the suspension at a static level position, at full extension (jack up the frame so wheels are off the ground and axles are hanging only by the springs), and compressed if you can (ask a dozen friends to climb on, or I can give you contact info for my ex-wife LOL). Give the measurements to the drive shaft shop in order to get the proper length. Depending on your setup you may need long travel slip yokes (are you planning to use shackle reverse kit?). Another thing you want to decide is the diameter and thickness of the tube you need...
gojeepin 06-22-2013 05:38 AM
I agree with Spieg8. You need to measure... your distance and your angles. While I don't cover the length measurement, you can read about all the other aspects of a lift in the article linked in my signature block.
CSP 06-22-2013 09:19 AM
I disagree with the bit about a transfer case drop. That's a band-aid for keeping the stock driveshafts. If you're getting new shafts leave the transfer case alone and get a CV type rear driveshaft, which will handle the steeper angle in the rear.
capt205 06-22-2013 10:55 AM
Just did the 4.5 RE lift. I went with the double carden shafts. I can measure them tomorrow. I did not use the transfer case drop that came with the kit.
JMcDonaldKnives 06-22-2013 11:31 AM
That would be great. Your measurements should be just about the same for mine. Are you running the same engine/trans combo that I am?
capt205 06-22-2013 04:10 PM
Yes I am...258, T176, D300, D30 front, and D44 rear.
I'm at the station today, so I'll post up the measurement tomorrow.
JMcDonaldKnives 06-22-2013 07:13 PM
Is there much difference between the driveshaft with a D44 compared to AMC20?
Cutlass327 06-23-2013 11:56 AM
Not much if any that I found. I just swapped from the 20 to the 44 and using the same driveshaft, although I didn't set the angles right (yet) so I don't know for definite if the shaft length is different. It works, but vibrates from the angle issues.
Don't guess. His measurement will be a good starting point, but don't have yours made until the lift is on and the angles are set. You only want to spend that money once, and shortening is a lot cheaper than lengthening if you got it wrong.
Spieg8 06-23-2013 03:41 PM
If I remember correctly (it's been quite a while), the yoke on the Dana 44 sits about an inch or so more forward than a Model 20 (slightly shorter driveshaft). They can use the same Spicer 1310 U-joint (some people like to upgrade to a beefier model).
capt205 06-23-2013 05:06 PM
Mine are as follows:
measurements are center of u-joint to center or u-joint
Front 31.5"
Rear 26"
Double Carden's on both
JMcDonaldKnives 06-23-2013 05:27 PM
Front 31.5"
Rear 26"
so a 27" should be just about perfect for mine in the rear and a 31" in the front. Thanks. But I will double check before I order anything.
The time now is 02:19 PM.
