what size brake Line - JeepForum.com
post #1 of 5 Old 01-27-2010, 08:25 PM Thread Starter
SonicR1
After starting to replace the Master Cylinder, I have realized that all the fittings, are some how siezed to the line, and removing them just twisted everything up... so now I get to re-run brake line.
What size line is it for a 74 CJ5???
SonicR1 is offline
post #2 of 5 Old 01-27-2010, 08:34 PM
Boodyrider
99% sure it's gonna be 3/16. Be real unusual not to be for that year. Salvage the fittings though, some may be hard to replace.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #3 of 5 Old 01-27-2010, 08:39 PM Thread Starter
SonicR1
How do I salvage them? the manual says once they are not repairable...
SonicR1 is offline
post #4 of 5 Old 01-27-2010, 09:07 PM
Boodyrider
Cut the line off near the fittings. Grind or drill away the line until you can poke the stub of line out of the fitting. Use those fittings, after cleaning, on the new line, making your own double flares. A decent double flare kit usable for anything but stainless line costs maybe 45 bucks. You'll then be able to make lines to any exact length you need anytime you like, instead of relying on unions and whatever length the local parts store has in stock.
It'll easily pay for itself, as your CJ5 will likely need fuel as well as brake lines over time.
post #5 of 5 Old 01-27-2010, 09:11 PM
Tigger01
I am at the present time having Classic tub make me up new master cylinder lines to the Proportionate Valve.
I am having custom lines done for mine because of changes I have done
Check them out Classictube.com their should be a phone # on the Website Also
I believe one line is a 1/4 and the other is a 3/16 line for a Standard Master Cylinder
Hope this helps
Chris-Tigger
Tigger01 is offline
What Size Brake Line Extentions??? poppatello Jeep CJ Forum 2 01-25-2010 09:54 PM
CJ-7 Brake Line Size RetiredSERE Jeep CJ Forum 2 06-15-2009 01:22 PM
Dumb Brake Line and Fuel Line Question GroundUpCJ7 Jeep CJ Forum 3 04-02-2007 07:01 PM
What is the brake line size? ClarkGriswold Jeep CJ Forum 5 08-13-2006 08:37 PM
what size brake line 84 cj7? CJ7 Vette Jeep CJ Forum 0 11-06-2005 08:05 PM
