What's a Nutter Bypass? - JeepForum.com
post #1 of 12 Old 04-05-2005, 12:52 PM Thread Starter
ollietonk
Just curious, What is a nutter bypass? Finally got the Jeep driveable and I'm looking for something else to break. Everyone seems to like it, but what does it do and how do you do it? Thanks for any info
86' CJ7 (258 w/ Howell TBI, 33" ProComp MT's)
ollietonk is offline
post #2 of 12 Old 04-05-2005, 12:58 PM
Slipslap
I'm not the expert seeing how I just found out. But a search on google will help. But I think it removes most of the emission stuff off the carb I think. There should be a post down here that we just talked about it. jeepskate helped me out with it.
Slipslap is offline
post #3 of 12 Old 04-05-2005, 01:05 PM
Slipslap
Here ya go. at the bottom jeepskate gave some links. Those helped me understand it. Hope this helps.
http://www.jeepforum.com/forum/f8/258-carter-yf-timing-mixture-issues-147740/
Slipslap is offline
post #4 of 12 Old 04-05-2005, 01:27 PM
Geer_hed
Geer_hed's Avatar
Archived Link to Nutter Bypass
off-road's copy
Dale's ignition mods page
The bypass takes the EECU out of the ignition loop and makes the Carter BBD Stepper Motor out of the feedback loop, eliminating irksome stepper interference with your idle and removing a single point of failure in the ignition loop. When my computer died, I went with the bypass instead of $140 to replace that POS...
85 CJ7 / 258 / T176 / Dana 30/ AMC 20
Geer_hed is offline
post #5 of 12 Old 04-05-2005, 03:29 PM
Dimension4
Does an edelbrock carb have a stepper?
Dimension4 is offline
post #6 of 12 Old 04-05-2005, 03:50 PM
Geer_hed
Geer_hed's Avatar
No. Atleast not in the same sense as the Carter BBD. The carter stepper has needles that can adjust mixture based on realtime feedback from various sensors as translated by the EECU.
This is what it looks like:
It's on the back of the Carter BBD, as pictured here:
If you're running an Edelbrock, then the EECU is already out of the emissions loop.
Geer_hed is offline
post #7 of 12 Old 04-05-2005, 05:02 PM
redlinedcj
what years did the cj's have that?
redlinedcj is offline
post #8 of 12 Old 04-05-2005, 06:11 PM Thread Starter
ollietonk
So with the MC2100, the stepper motor is already out of the picture. No nutter bypass for me Would this be correct.
post #9 of 12 Old 04-05-2005, 06:13 PM
wm69
I did the MC2100 swap but I did the nutter anyway and noticed a smoother idle. Doing the nutter takes the ECU out of the ignition system too.........
wm69 is offline
post #10 of 12 Old 04-05-2005, 07:17 PM
Jeep Daddy
Jeep Daddy's Avatar
That's where you go to the hospital and they hook up a peanut butter pump directly to your stomach so you can get mass doses for a quick recovery. LOL
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #11 of 12 Old 04-05-2005, 08:14 PM
gunkysputter23
82-86 I believe.
gunkysputter23 is offline
post #12 of 12 Old 04-05-2005, 08:50 PM
Geer_hed
Geer_hed's Avatar
Production Jeep CJ didn't implement the Feedback System until 1983, but I've found that certain models (such as the California Emissions Package) started as early as 1981.
If you have the MC2100, the only thing the nutter does for you is take the EECU out of the pickup coil / Ignition Module chatter loop. If you're not too worried about Etesting, do it!
Geer_hed is offline
Nutter Bypass... poppatello Jeep CJ Forum 1 06-27-2009 06:19 PM
nutter bypass bulljeeper Jeep CJ Forum 2 06-25-2007 02:13 PM
Nutter Bypass Trooper3385 Jeep CJ Forum 10 05-29-2007 02:08 PM
nutter bypass sailkid Jeep CJ Forum 1 05-24-2006 06:12 AM
Nutter bypass sharkbait Jeep CJ Forum 5 05-16-2006 05:37 AM
