What's a good way to determine CJ value? - JeepForum.com
post #1 of 22 Old 02-16-2012, 02:07 PM Thread Starter
flashstang04
I have had everything but a CJ and am looking at one currently. It's a 75 CJ5. Small lift with great tires. Runs and drives great. New paint, etc. Odo shows 85k so more than likely 185k I would think. 4.2 liter.
So I see CJs from $2000 to $8000 and would just like a good way to judge the value. It seems to be more varied than YJs and TJs, etc.
Here is a pic as it sits today.
2004 Electric Green "X"
flashstang04 is offline
post #2 of 22 Old 02-16-2012, 02:23 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The best way to determine value is to stick a "For Sale" sign on it and see what kind of offers you get.
As a buyer, I'd be leery of what's under that fresh paint. And the tires look too big for the lift, to me. I suspect they rub at full flex.
I like the general appearance of it, but there just doesn't appear to be anything special about the condition, or the build. I'd say you'd be doing well to get $3-4K out of it.
Take it for what it's worth.
Matt
Matt1981CJ7 is offline
post #3 of 22 Old 02-16-2012, 02:43 PM Thread Starter
flashstang04
Thanks. I am actually looking to buy one though and this one is in the $4000-4500 range. If it's a fair price I'll probably move on it.
post #4 of 22 Old 02-16-2012, 02:48 PM
CJ7Sasquatch
1979 CJ7
Crawl under and look at the metal, especially where panels meet and body meets panels, look up in the rear wheel wheels where the roll bar is bolted and look for rot, check gauges, electric, and steering for pull or swerve. Make sure you put it in 4x4. If all looks good go for it just go over it, there's always a surprise or two on a thirty year old vehicle
ECV 1864
CJ7Sasquatch is offline
post #5 of 22 Old 02-16-2012, 02:53 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
That's way too much for an early 5 in that condition.
Now if it was a cleaner rust free west coast Jeep up in the rust belt,
Then it might be priced right.
LT1CJ7 is offline
post #6 of 22 Old 02-16-2012, 02:58 PM
84scrambler
1984 CJ8
That looks like just a plain CJ-5 with questionable value. The paint job looks fairly new and done in a hurry. It looks like it just got taped off and sprayed which would make me question the quality of whats going on under the paint. Most everything looks stock, with perhaps a mild lift.
The biggest things you want to look at is what kind of rust does it have, check the usually places, floor pan, frame body mount areas, by the rear hangers. Check the suspension and steering hardware, tie-rods, bushings, and ball joints. Any huge leaks coming out of the steering box, engine, tranny or transfercase. Does it have a full top and doors? All of this stuff adds up.
I see CJ7's for 3-4k without a top and doors and ****ty tires. Those three items alone can easily set you back 2k so it really depends on what you want out of the vehicle and how much it will cost you to bring it up to a reliable rig.
84scrambler is offline
post #7 of 22 Old 02-16-2012, 03:02 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
It's priced @ $4,500 with mismatched seats.
Maybe he thinks the diamond plate dash patch has the same value as real diamonds
I know, The keys are a $2,500 option
LT1CJ7 is offline
post #8 of 22 Old 02-16-2012, 03:04 PM Thread Starter
flashstang04
Thanks for the replies. As far as the paint it does look like it was done in a hurry. I know it's at least a year old though. Mechanically it drives really well. It made a trip to Amarillo Tuesday. The floor pans have been patched so I know that there were problems at some point. There aren't any doors or a top. I'll check out the roll bar attachments.
post #9 of 22 Old 02-16-2012, 03:11 PM
1984CJ
1984CJ's Avatar
Or wipers, or door hinges. What else is missing or jury rigged?
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline
post #10 of 22 Old 02-16-2012, 03:22 PM
My83andMe
1983 CJ7
I've gatta agree the tire do look to big for the lift. I'd check for tire rub in a turn from wheel stop to wheel stop as well. It does look nice with room to personalize it to you. Just be sure to put it through all the gears and try 4wd. Check linkage and wiring. And maybe even run it in for a quick compression test to make sure things on the inside are good to go. Honestly I wish I would Have on my 83 4.2
I thank you and believe me my Jeep definatly thanks you cus otherwise I'd be turning a wrench with out a clue. :)
My83andMe is offline
post #11 of 22 Old 02-16-2012, 03:29 PM
Matt1981CJ7
1981 CJ7
Sorry, I read your original post too fast.
As mentioned, take a hard look at the underside for evidence of rot, especially the frame.
When you schedule to test drive it, ask the owner to avoid starting it for few hours before you get there. That way you can check for proper operation of the carb/choke on a cold start. Pull a couple of plugs and check for fouling, or evidence of ignition problems.
Obviously, any grinding as you run thru the gears should be a warning sign, both in 2WD and 4WD. Lifted CJs are notorious for wandering all over the road if they aren't setup appropriately, so pay close attention to how well it tracks and returns to center on a turn. Watch for any smoke coming out the tailpipe, especially when you get on it a little.
Hope this helps.
Matt
post #12 of 22 Old 02-16-2012, 03:35 PM
foggybottombob
The easiest way I know of to determine the value of anything is to watch similar things sell on ebay for a couple of weeks. The selling prices of similar items on ebay are remarkably stable.
foggybottombob is offline
post #13 of 22 Old 02-16-2012, 03:48 PM
Matt1981CJ7
1981 CJ7
foggy,
I love the pic you use for an avatar, but I pucker up every time I look at it.
Matt
post #14 of 22 Old 02-16-2012, 03:49 PM
walkerhoundvm
1981 CJ8
It's in Texas? Take price, divide by 2.3. That is the actual value in the rest of the United States.
walkerhoundvm is offline
post #15 of 22 Old 02-16-2012, 03:59 PM
74Maverick
Try finding a clean one in ohio guys around here ask 5000 for anything that doesnt have visual holes in it.
The Last Great American Hero... the demi-god... to which speed means freedom of the soul.
74Maverick is offline
How do you determine RMS or VC leak? 2Xtreme Jeep CJ Forum 3 09-12-2011 03:40 PM
How to determine condition of AMC 360 Dad03 Jeep CJ Forum 6 08-27-2009 09:46 AM
How can I determine how much lift? djmart Jeep CJ Forum 15 07-20-2009 06:26 PM
How do I determine how much lift i have colby72olds Jeep CJ Forum 12 06-29-2009 12:12 AM
