what is the proper way to set timing on a 1979 cj5 with a 258 - JeepForum.com
post #1 of 7 Old 08-26-2013, 04:13 PM Thread Starter
jennkent5454
1979 CJ5
I want to check and adjust the timing on my 1979 258, carter BBD, team rush upgrade. Im looking for the correct steps to get it done. how to get TDC and being sure what stroke its on. and what setting the timing should be at, and does it have to be up to temp first?, and, and, and!!!
jennkent5454 is offline
post #2 of 7 Old 08-26-2013, 08:24 PM
fourbtgait
1930 MK Patriot
Under search in cj forum, type in "finding top dead center or TDC" by Shawn.
It is easy to do to verify your balancer is correct, then go from there.
fourbtgait is offline
post #3 of 7 Old 08-26-2013, 11:13 PM
BagusJeep
1981 CJ7
Timing can be done cold or hot, at idle with the vacuum advance unplugged. A timing light is needed and you may find good results wih 8 degrees BTDC. Slacken the distributor retianining bolt and turn it until you get 8 degrees on the timing light.
However you may then think that you could do more........... and this is when you will need the Forum. There are threads on here of great complexity and length about measuring, setting up and getting the most from the timing curve.
You will rapidly descend into a world of graphs, tachs, capsules and flips as you search for that elusive perfect curve.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 7 Old 08-27-2013, 05:37 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by BagusJeep View Post
...You will rapidly descend into a world of graphs, tachs, capsules and flips as you search for that elusive perfect curve.
and down the rabbit hole you will go..........
It CAN get very complex. But the process itself very simple.
2Xtreme is offline
post #5 of 7 Old 08-27-2013, 05:38 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
^^ This
2Xtreme is offline
post #6 of 7 Old 08-27-2013, 08:38 AM Thread Starter
jennkent5454
1979 CJ5
So do I need to find TDC before I put a light on it? Or can I just put the light on it and set it to 8*?
post #7 of 7 Old 08-27-2013, 08:46 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The reason for finding TDC is to confirm the timing marks jive. When the engine is at TDC the mark should be sitting at zero. If it's not, then the timing chain has stretched, perhaps even jumped a tooth, giving you inaccurate readings with light.
Good luck,
Matt
Matt1981CJ7 is online now
