What are people referring to when they talk about "lockers"? - Page 2 - JeepForum.com
post #16 of 25 Old 02-04-2010, 01:16 PM
Coiz
1979 CJ7
Originally Posted by JeepHammer View Post
I DO get tired of having to unlock the front lockouts to get around tight turns off road,
Twin Stick? It would at least keep you from having to climb in and out of the Jeep.
Mike
Coiz is offline
post #17 of 25 Old 02-05-2010, 02:41 AM
pazur
1981 CJ7
So you are saying that gear-driven detroit behaves different than lunch box lock-right or aussie on dry pavements? I doubt (yet I never driven detroit). All these auto lockers momentarily unlock when there is pre-set difference of forces between wheels. To date no one has been able to design a locker that behaves like open differential on road and turning and locker off road/straight movement without human/computer control.
For example, when turning right, the right wheel force push to the rear and left wheel push to the front. This difference depends on speed, degree of turn and friction between pavement and tire. If any of these variable is low your jeep understeers with rwd in turning maneuvers, especially at low speeds and low traction (rain, snow, ice, mud). You can surely set this difference to be lower, however axle may then unlock even in straight movement (when we want it to be locked).
Manual locker is therefore the only rational way, perhaps not for a buggy that never sees a paved road.
pazur is offline
post #18 of 25 Old 02-05-2010, 08:20 AM
JeepHammer
Running On Empty...
1973 CJ5
Twin Stick Dana 20 isn't practical, since there is only ONE place I go regularly that gives me fits...
It DOES happen to be really soggy most of the year!
Just my luck!
Besides, front digs with a Dana 30 isn't the best idea I've ever heard!
I can here the broken axle U joints from here!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #19 of 25 Old 02-05-2010, 08:36 AM
1jack5
WOW, you cj guys are pretty cool fellas, please do not get offended by this, but if this question would have been asked in other forms he would have gotten blasted w/ USE THE SEARCH STUPID!, or IF YOU DONT KNOW LOCKERS YOU SHOULDNT OWN A JEEP! kind of stuff. yall are pretty cool for actually helping instead of bashing him. props to all of yall!
1jack5 is offline
post #20 of 25 Old 02-05-2010, 09:05 AM
JeepHammer
Running On Empty...
1973 CJ5
That's EXACTLY what I'm saying.
Full time lockers lock, unlock, drag/spin the off side tires, make all kinds of jerking, popping, ect. when you are going around corners on pavement.
They only have TWO settings, Locked & Unlocked,
And as little as three inches of tire rotation will lock and unlock them,
Axle shaft speed differential is what determines if they lock or unlock, and you have no 'Practical' control over when they lock or unlock.
With a Detroit TrueTrac (and other gear driven Limited Slip differentials) they use a series of gears in the case to 'Sense' when one wheel needs power and the other needs to free wheel...
The ones I'm running is a 70/30 split, so one wheel can be running 70% faster around a corner and still get at least 30% of the power, BOTH still getting power and traction.
Here is a image of the 'Guts' of a TrueTrac, no locking 'Teeth'....
Like I said, it's the next evolution in 'Limited Slip' differentials... And it's been around since the early 70s when it was practical to produce.
Since there isn't anything 'Locking' or 'Unlocking',
Both wheels are being driven at all times, but at different rates to accommodate the varying speeds of the wheels, but both wheels get some percentage of power full time.
Mine will still pull it's self with one wheel completely off the ground since no matter what, I'm still getting 30% of the power to the wheel that HAS traction...
That wouldn't happen with a clutch pack limited slip since the wheel with traction would 'Slip' the clutches and the one with no traction would simply spin (at TWICE the rate the speedometer registers!)
Actually, it's differential between drive shaft rotation and axle rotation.
One axle isn't driving 1:1 with the drive shaft, the locker engages.
Tolerances in the spacing of the locker engagement teeth (or pins) determine how much one axle gets to goof off before the locker teeth reach each other,
So there really isn't any practical way to set a locker up for when it engages or disengages.
As long as the axles speeds are even, the locker doesn't force the driven plate teeth (axle) into the drive plate teeth (differential) and you have an 'Open' differential.
When you have one axle moving slower (or sometimes faster) than the other axle/carrier, then the forcing mechanism kicks in automatically and LOCKS the axle that is not moving with the carrier into the carrier.
You don't get ANY say in the matter, it 'LOCKS' one axle (or BOTH axles) into the carrier when the axle speed isn't the same as the carrier speed,
And that causes REAL problems when you are on slick pavement, makes a BUNCH of noise, and is generally unsafe since it CAN cause the back end of the vehicle to break loose and do something it shouldn't in traffic.
That's why nothing but a few 'Racing Only' muscle cars came from the factory with true lockers,
And why there are so many designs of 'Limited Slip' & 'Posi-Track', 'Track Lock' differentials out there that DO NOT lock the rear wheels together.
They were simply unsafe on the street for the 'Average' driver and caused accidents...
Accidents cause law suits, and they didn't need the law suits so they don't use them.
That isn't entirely a true statement.
The Gear Driven Limited Slips have been used in racing for quite some time because of their very nice high speed operation.
We used them in Indy (Champ) cars in the very early '70s and they gave us an edge on the people that weren't using them,
Thorsen-Gleeson designs have been permeating racing since the early 70's, and the Detroit TrueTrac is living proof the concept exists and works well.
The 'Stabili-Trac' system uses a gear driven limited slip,
It simply hazes a brake on the spinning wheel, and the differential lets the braking of one wheel at a time where you couldn't do that with a locker.
Staili-Trac also reduces engine power, and that is purely electronic with modern fuel injection.
I took a modern full size SUV out and TRIED to make it spin in the snow on a parking lot this year, and it simply WOULD NOT spin a tire with the traction control turned on!
You COULD NOT make it spin a tire or lock up a tire!
Couldn't do that with a 'Locker'....
We did, however, still have all 4 wheels turning when we decided to climb snow piles with it!
Now you are talking about an UNLOCKED front trying to seer a vehicle that is pushing from the rear...
I'm not saying if it's slick enough, you WILL NOT push the front in a straight line,
Especially if you brake hard (what most people do) and break traction with the front tires...
If you have a 'Locker' you will make the front tires 'PLOW' instead of 'Turn' while keeping traction.
If it's slick enough, ANY drive in the rear will do that same thing.
What I'm talking about is being able to let one rear wheel REDUCE or INCREASE speed in a controlled manner,
Allowing you to make a turn with *SOME* traction in the front.
When a locker pops 'In & Out' it can break what traction you have in the front, and you 'Plow' no matter what...
If you have NO TRACTION for the steering tires, you are going to 'Plow' no matter what,
But something like the TrueTrac lets you keep what ever little amount of traction you have in the front, and the vehicle still turns on command,
And/Or the back end doesn't come around you while you are trying to turn,
Like what OFTEN happens with a locker that decides to 'Lock' at the wrong time!
Study up on the gear driven (non clutch) Limited slip units.
It's worked GREAT for me, and I don't have to worry about a little, short CJ-5 turning backwards every time the locker decides to do something stupid!
This TrueTrac has REALLY made my little 360 powered CJ-5 about 100% more drivable than the earlier Detroit Locker I had in there!
It was inherently unsafe on highways aorund here since this is farm country, nearly every side road, curve & intersection has sand, gravel, mud, grain...
(makes motorcycle riding interesting too!)
...Something spilled in it, and I had more than one 'White Knuckle Ride', followed by needing clean shorts!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #21 of 25 Old 02-05-2010, 10:26 AM
Coiz
1979 CJ7
Just my luck!
You referenced having to get out to unlock your front hubs so I was thinking a twin stick would be the quick way to unlock the front axle only without having to get out of the Jeep.
Mike
Coiz is offline
post #22 of 25 Old 02-05-2010, 10:51 AM
Mike Romain
That isn't really the issue, the two sides are locked together so they won't allow it to turn no matter if the driveshaft is under power or not. The only way to release it you have to unhook one hub.
Mike
Mike Romain is offline
post #23 of 25 Old 02-05-2010, 10:57 AM
rklaahsen
1980 CJ5
Thanks for the info Hammer. Well written and informative.
rklaahsen is offline
post #24 of 25 Old 02-05-2010, 12:37 PM
JeepHammer
Running On Empty...
1973 CJ5
I learn something every time I get on here!
There are so many guys in different disciplines here, and about 95% of the crowd doesn't act like children, so you can REALLY learn a lot if you are willing to read and do a little research!
I REALLY like this forum, that's why I spend so much time here.
I wish our company forums were so well behaved and had so many knowledgeable people!
I wouldn't have to spend so much time editing and deleting post there!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #25 of 25 Old 02-08-2010, 01:15 AM
pazur
1981 CJ7
jeephammer TrueTrac you are describing is a compromise between open dif and full locker (best difs for onroad and offroad application). Gear driven dif does not differentiate whether it should stay locked (wheel spinning) or unlock (turning). By reducing rotations to slower axle up to 30% may be too low for some in no-traction condition and too much in low speed, parking lot-like driving. In low speed driving i.e. when less than 30:70 difference betwene axle speeds (e.g. 20:80) TruTrac dif poses stress on driveline because 10% difference must be compensated by slipping tires.
IMO for racing car limited slip is OK. For pure, offroading community demands full locker. Nearly all military trucks since 1950s US, german unimogs, russian zils, chinese, indian, have mechanical, driver actuated locks instead of posi or open dif. IMO aussie-type is more friendly to axles stress than spool (arb, ox etc.). Electronic lockers are different story, a good topic for vw tuareg forums. By the way good and informative writing!!
pazur is offline
Talk to me about Aussie lockers zillla Jeep CJ Forum 2 09-04-2009 04:36 PM
JKS "Quick" or "Quicker" disconnects? cincyjeeprs Jeep CJ Forum 0 05-15-2009 09:33 AM
"Green Grease" or Lucas "Red N Tacky #2" Curt Reinhardt Jeep CJ Forum 3 07-16-2008 07:09 AM
3" Black Diamond: Opinions People!! sweetguardian00 Jeep CJ Forum 5 05-13-2008 01:22 PM
backspacing required for 35" tires & lockers njrealtor55 Jeep CJ Forum 1 02-11-2004 08:06 AM
