What are people referring to when they talk about "lockers"? - JeepForum.com
post #1 of 25 Old 02-02-2010, 02:05 PM Thread Starter
HHICJ7
For example I hear about "detroit lockers", etc.
Thanks!
HHICJ7 is offline
post #2 of 25 Old 02-02-2010, 02:07 PM
Coiz
1979 CJ7
Differential lockers replace the ring gear carrier, or the pinion and side gears inside of the stock carrier, so that both axles get power applied when there is input on the pinion gear. When you see a car doing a burn out and only the right rear wheel is spinning, that is an "open" differential. When you see a car doing a burnout and both rear wheels are spinning, that is a "locker".
Here is a picture of an open carrier, notice it has side gears and pinion gears in the middle of the carrier case,
And here is a picture of a Detroit easy locker that replaces those gears. These types are commonly referred to as a soft locker.
Here is an example of a stock open carrier and a Detroit True-Trac. Notice the True-Trac completely replaces the stock ring gear carrier.
And finally, this is the notorious Detroit locker, it also completely replaces the stock carrier.
Mike
Coiz is offline
post #3 of 25 Old 02-02-2010, 02:16 PM Thread Starter
HHICJ7
So you can put lockers in any 4wd axle? Dana 30, etc. Or, do you have to buy the axle with the lockers pre installed. Thanks!!
HHICJ7 is offline
post #4 of 25 Old 02-02-2010, 02:22 PM
Coiz
1979 CJ7
That second picture is of my D30 front axle with a Detroit EZ-locker. They can be installed in almost any axle. The nice thing about an EZ locker is that they can be installed with minimal tools and experience. They also do not require the ring and pinion to be re-setup but they are also weaker than a full case locker. When installing a full locker, one that completely replaces the stock carrier, you will have to re-setup the gears. ex. pattern, backlash, bearing preloads, ect.,. That typically takes a few special tools and some know-how. Any axle commonly installed or swapped into a Jeep can have a locker installed at anytime.
Mike
Coiz is offline
post #5 of 25 Old 02-02-2010, 04:52 PM
CaliDaze
1981 CJ7
Theres a ton of different applications that lockers are ideal. But also some that are not, depending on what your doing in your machine. Some places an open diff is better and others where a full locker is best.
This topic has been discussed by many users with many different opinions. The best way to get those opinions, sort through them and decide which will best work with your application and preferred type of wheeling is to use the SEARCH on the toolbar.
Im telling you this because that is a Topic Title that most will look at and think 'Im so sick of talking lockers that Im not even going to open this thread'. Do some research, youll see a couple of Names that re-appear thread after thread with great information to share. When you have a specific question ask them.
CaliDaze is offline
post #6 of 25 Old 02-03-2010, 04:40 AM
pazur
1981 CJ7
i do offroading for some time yet still waiting to meet someone who prefer open dif against the locker. the discussion is more about what type of locker is better (posi, easy, full, half-full) and what actuation (auto, mech, pneumatic, electric)
pazur is offline
post #7 of 25 Old 02-03-2010, 08:22 AM
Mike Romain
Well, now you can say your 'have' met someone who prefers open diffs to lockers that are not selectable (off on option).
I wheel all year round up here in The Great White North and have a cabin on a two track 'Jeep' road where we are staying lots. Plan on moving there permanently.
They call lockers 'low side finders' which makes them almost impossible to use on narrow snow or ice covered trails or on snow and ice covered paved roads. You have to have room to crabwalk sideways up the trails or you are ditched. Paved roads all have a crown to drain water to the ditch side or to drag a locker into the ditch...
Last week I tried to drive a Cherokee with a front locker onto the cabin and there was just plain no way to keep it on the off camber trail in 8" of wet heavy snow, we ended up on the arse end of a neighbours tractor getting dragged back out. Kinda embarrassing...
So then we hiked into the cabin and got the CJ7 that had to be left in there 4 months ago with it's open diffs and 33x9.5 BFG AT's and it just purred on out, not a slip of a tire or any issues with staying on the track. There was a fresh 4 more inches of snow down too.
I can also 'lock' up my diffs for a start off if needed by using the brake. If stopped on ice with one front and one rear tire spinning away, I can hit the brake pedal hard while giving it gas which will load up the spinning tire and break the other side free. The CJ owners manual says you can also do this with the emergency brake, but I have better luck with the main foot brake.
What happens is an open diff sends the exact same torque to 'both' axles. So if one is spinning on ice, it sees almost no torque so the other tire on the dry stuff also sees no torque and you go no place fast. When you load up the free spinning wheel with the brake, the torque has to rise against the brake drag which will raise the torque on the stopped wheel until it also has enough torque to break free and away you go shooting 3 or 4 rooster tails.
It takes some practice, but it does work.
Mike
Mike Romain is offline
post #8 of 25 Old 02-03-2010, 02:46 PM
CaliDaze
1981 CJ7
Thanks for backin me up mike.
CaliDaze is offline
post #9 of 25 Old 02-03-2010, 06:46 PM
80cj
80cj's Avatar
1980 CJ5
Coiz,
Hope you don't mind a little correction. You describe your second pic, the Detroit Easy locker, as a soft locker. Actually, the Easy Locker is an example of a lunchbox locker. Soft locker is a current version of the Detroit (full carrier) locker as in your last pic.
80cj is offline
post #10 of 25 Old 02-03-2010, 08:41 PM
JeepHammer
Running On Empty...
1973 CJ5
Thanks!
OK, I'm going to start very basic, since I don't know your skill level...
"Detroit" is a brand name, like 'Spicer', 'Bendix' or 'MSD'...
They make VERY tough drive line components and have a very good reputation for durability.
Some other 'Locker' brand names are OX, Aussie, Lock-Rite, ARB, ect.
The term 'Locker' comes from people saying the 'High Traction' differential carriers 'Lock' the rear wheels together during operation.
Normal operation, you don't need a 'Locker', and if the rear wheels are 'Locked' together, you can't go around corners without twisting one axle or the other.
When you go around corners, one wheel MUST move faster than the other since the OUTSIDE wheel has to go a farther distance in the same amount of time the INSIDE tire does.
'Open' differentials will allow one wheel to 'Free Wheel' to accomplish this turn radius difference.
If you have the wheels locked together,
You will be twisting axle shafts, skidding tires on the pavement or the vehicle will find some way to balance the load being inflicted on the differential/axles/tires by that different loading side to side.
I've seen MANY a broken axle from the stress,
And when the two wheels are locked together, the vehicle steers very strangely since the BOTH wheels are trying to push the front end straight down the road instead of turning.
What a 'Locker' does is allow one wheel to 'Unlock' when you are going FORWARD around a corner, and you aren't applying enough power to make either wheel slip on the pavement.
If you apply power around a corner, and one wheel slips FORWARD, the differential carrier will 'Lock' both wheels together and one of two things will happen,
1. Both wheels spin and the back end swings around very quickly since all the differential/tires are trying to do is 'Get Straight' and unload the uneven force.
2. You will push the front tires in a straight line with the rear axle, no matter what direction the tires are turned to.
3. If you spin the tires fast enough to brake BOTH tires completely loose, you will come completely around and be facing the 'Wrong' way very quickly!
Since BOTH tires have no traction to speak of, the momentum of the vehicle will carry the back end right on around, usually scaring the crap out of anyone unlucky enough to be coming at you in traffic!
Now, since 'Lockers' are designed to 'LOCK' when the tires are rotating FORWARD, you get some even stranger things going on when you are in REVERSE!
Some people call it 'Fork Lift' steering, and they are VERY close to being correct, but not for the same reason forklifts do strange things...
Lockers do STRANGE THINGS in gravel, on sand on the roads, they are virtually uncontrollable on ice...
That's why some lockers are 'Selectable',
Meaning you can turn the 'Locking' feature 'On/Off' at will.
This lets you drive SAFELY on highways, rock roads, places where they have scattered sand or sand has blown onto the roads...
And you can turn it 'Off' when you are on wet pavement, ice or on gravel/sand so the back end doesn't jump out from under you without notice.
There are the 'Gear Driven' & Clutch plate differentials called 'Limited Slip' units, since true 'Lockers' are inherently unsafe on highways...
(let the flames begin, but there is a reason they aren't installed in passenger cars anymore)
The clutches allow a limited amount of power to reach both wheels, and when one wants to Unload, it can 'Slip' the clutches and do so safely for both the driver and differential/axles.
The draw back to clutches is they wear out quickly and leave you with an 'Open' differential,
They WILL NOT give you power to a wheel that has traction if the other wheel has NO traction,
Say on wet clay or ice,
And they require specialized maintinance, additives to keep the clutches from binding, ect.
About 1970 or so, All gear driven Limited Slip Differentials came into common use,
And they are the next step in evolution for the Limited Slip.
The gear driven differentials (Detroit 'TrueTrac', ect.) will apply a 70/30 split to the wheels so BOTH wheels will get some power no matter if one is off the ground!
They don't pop, crack, spit out clutch plates and they pull on BOTH wheels.
The secret is, no matter how long or short the turing radius is of any vehicle,
One tire is NOT going to exceed the wheel speed by more than 70%,
So the gear sets can transfer AT LEAST 30% of your driveline torque to the wheel with the MOST traction, no matter what.
I've gone through a BUNCH of lockers of all styles,
And the Detroit TrueTrac has done the best job for me in the back of my vehicle...
Never has to be turned 'On/Off', is always ready, never does anything stupid, doesn't load/unload unexpectedly and doesn't make the first noise in operation like other Limited Slip or Locker differentials do.
Then you get into full on 'Lockers'...
The most popular is the 'Lunch Box Locker'...
Named from an article in a magazine a few years back.
The premise was...
Because you can take one to work in your lunchbox, and install it over your lunch break...
Silly name, but the name of that article stuck like glue!
Anyway, 'Lunch Box' lockers are CHEAP! Around $200 to $300 for most axles,
And they fit in the factory 'Open' carriers,
So you don't have to remove the carrier or set the ring/pinion gears back up like you have to when you replace differential carriers for a Full Size locker.
I run one in the fronts of Dana 30 equipped jeeps that have lockouts on the hubs and two wheel drive transfer cases...
By unlocking the hubs and putting the transfer case in 2 wheel drive, you have 'UNLOCKED' the locker in the front and it's not going to do anything stupid while you are on gravel or pavement.
Since the Dana 30 is such a weak axle all around,
Small ring & pinion that likes to break,
Weak axles,
Weak U joints between axle pieces, Ect.
There really isn't any sense in spending a bunch of money on a Dana 30 front axle,
You are MUCH better off with a Dana 44 in the front to start with if you are 'Serious',
Or just keeping the Dana 30 mostly stock, adding a $200 LockRite or Aussie 'Lunch Box' locker to it and going down the trail with a big grin on your face if you aren't a 'Hard Core' wheeler...
Most of the time, I tell the part timers that come in here to look for a factory limited slip, rebuild it with new clutches and it will do everything a 'Cheap' locker will do without the headaches full time lockers bring to the table...
Or if they have a fat wallet, go with a TrueTrac gear driven limited slip in the rear...
That way, you have 'Posi', or both wheels turning in the rear, without remembering to 'Turn On' the locker, and 'Turn Off' the locker when they are done,
And don't have the driveability problems that come with 'Full Time' lockers...
If you are a serious wheeler, you WILL want to spend CUBIC DOLLARS and get a 'Selectable Locker' you can turn on and off at will from the drivers seat...
Serious wheelers will have LARGE, AGRESSIVE tires that don't like to be skidded and give great traction, so they will load the axle shafts to no end when going around corners,
And if they are 'Serious', they have enough horse power to push the front end stright no matter which way the wheel is turned...
Selectable lockers are NOT CHEAP!
But they ARE the only way to get around tight turns on slick trails without getting in and out of the vehicle all the time...
They will cost you $1,000 by the time you buy them,
Regear for large tires, and have them installed!
Since I have to run wiring, cables, compressors, tap electrical circuits, ect.
I won't touch a selectable locker install for less than $500 an axle, and the lockers are normally $750 to $1,250 each before gears and install.
The 'Cheap' way to go for someone 'Semi-Serious',
IE: Vehicle is still street driven and is leagal for streets, but you still get into the 'Out Back' with it on weekends)
Is a $650 True Trac in the rear, all the qualities of a full on 'Locker' without having electrical/air/cables to turn them On/Off.
They are a full size differential carrier, so you WILL have to set up the ring/pinion again, and that should run $250-$300 in a reputable shop.
In the front, if you already have lockouts on your hubs and 2 wheel/4 wheel drive transfer case
(NOT FULL TIME TRANSFER CASE!)
Then consider a 'Lunch Box' locker for the front.
Easy to install, doesn't 'Eat' anything or do anything stupid when in 2 wheel drive.
About $200-$300 for the locker and another $75-$150 for install if you don't do it yourself.
I haven't been 'Stuck' since I went 'TrueTrac' in the rear and 'Lunchbox' in the front with my highway driven Jeep, and I'm in the often VERY MUDDY river bottoms on the farm about 3 days a week...
And I take it to the local 'Off Road' parks, drive it there, and drive it home afterwards...
I'm not saying you won't get 'Stuck', I'm saying that you will do things with that Jeep you sure couldn't have before!
(Winch is ALWAYS a good investment if you get into the soup very much!)
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #11 of 25 Old 02-04-2010, 01:17 AM
pazur
1981 CJ7
If you have lockers on both axles you should be fine on snow/ice. locker on rear axle only is not a good idea because of steering.
Man (hammer?) are you expect us to read all this?
IMO ultimate locker is electric or cable actuated that partialy differentiates. Such locker has not been made to date.
pazur is offline
post #12 of 25 Old 02-04-2010, 08:57 AM
Coiz
1979 CJ7
My 2009 F150 has an electronic locker in the rear axle. Acts as an open differential until placed into 4x4 and the locker switch activated, pull out the 4x4 knob in this situation.
Mike
Coiz is offline
post #13 of 25 Old 02-04-2010, 09:32 AM
JeepHammer
Running On Empty...
1973 CJ5
Only if you are doing research before spending large bucks for lockers...
Knowledge is the difference between 'Correct' selection of something you will be happy with and works well,
And falling for a flashy picture in an advertisement and being VERY unhappy when the back end comes around and you get hit by a truck!
Forget the cable or activation line,
The Detroit TrueTrac does do what you describe without any outside input.
Works well on rain slick, ice, sand/rocks on pavement, gravel roads, and still gives me enough traction to turn BOTH rear wheels when in the slickest clay mud around here,
Plus it doesn't do anything stupid to the steering on slick off road situations or dry pavement!
For guys with 'Part Time' off roaders like my little CJ is, it's the best thing I've used so far...
And I've run everything from full on spools and welded up open differentials to the factory open differentials running them 'As Is'....
I've tried about every type of 'Limited Slip' from clutches, forcing cones, and gear driven,
I've tried about every kind of locker, Lunch box, Full Size/full time to selectables,
And so far, for 'Combination' or 'Part Time' off road vehicles, My OPINION is that the gear driven limited slip in the rear is the best way for ME to go.
Lunch box in the front
(if you don't have a full time transfer case)
And Gear Driven Limited Slip in the rear so it doesn't do anything stupid when traction slips on hard roads...
I DO get tired of having to unlock the front lockouts to get around tight turns off road,
But since I'm not going to put any money into the stock Dana 30 in the little jeep, I'll put up with it for now...
*IF* the little jeep gets a Dana 44 in the front, then I'll spring for a selectable in the front, or maybe just use a True Trac in the front also...
I need to look into that! That's a good idea!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #14 of 25 Old 02-04-2010, 10:09 AM
JoonHoss
2011 JK Wrangler
Thanks!
I just always assumed they meant these?
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #15 of 25 Old 02-04-2010, 10:34 AM
mcmud
1983 CJ8
You gotta love this ^ guy
mcmud is offline
Talk to me about Aussie lockers zillla Jeep CJ Forum 2 09-04-2009 05:36 PM
JKS "Quick" or "Quicker" disconnects? cincyjeeprs Jeep CJ Forum 0 05-15-2009 10:33 AM
"Green Grease" or Lucas "Red N Tacky #2" Curt Reinhardt Jeep CJ Forum 3 07-16-2008 08:09 AM
3" Black Diamond: Opinions People!! sweetguardian00 Jeep CJ Forum 5 05-13-2008 02:22 PM
backspacing required for 35" tires & lockers njrealtor55 Jeep CJ Forum 1 02-11-2004 09:06 AM
