what part is this??????? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > what part is this???????
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wdMarch Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 02-06-2015, 10:25 AM   #1
cookingguy
1979 FSJ Cherokee
So I am starting to put together all the vac lines for my 360 swap into my cj 5 and I have a bunch of parts I got off a waggy for my smog equipment which I need in place to pass the ca smog check. I am not sure what this part is called and where it goes. Can you guys help me out here?
cookingguy is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 10:43 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
That looks like a PCV line solenoid. As far as I know they never worked right and were a recalled part that didn't get replaced, it got tossed.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 10:48 AM   #3
SilverAnnCJ5
1979 CJ5
I can't help ID that part. But I can help with CA smog. I have the 360 in my CJ5. I have it set up with all emissions equipment as 79 304. Couldn't find all the parts for 360 emissions. Took it to the referee and it passed. Get yourself a FSM for your year jeep. It will help a lot with ID of all the parts.
SilverAnnCJ5 is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 11:07 AM   #4
cookingguy
1979 FSJ Cherokee
The reff I have talked to said o have to do all smog equipment as an 84 waggy since that was the year my engine casting was used till. So all smog must be as it was on a 84 waggy
Unread 02-06-2015, 11:16 AM   #5
SilverAnnCJ5
1979 CJ5
That's strange. My engine casting never came up. Maybe it's older than 79. It was a rebuilt engine that I got in another jeep so I don't know the details. It originally had no smog equipment on it at all so I pieced it all together myself.
Unread 02-06-2015, 03:16 PM   #6
streetpro
Observing GIC
streetpro's Avatar
1978 CJ7
They used the same casting numbers for many years. I was told the emissions was based on the actual year of the motor and not the "last year" that number was used.
streetpro is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 03:39 PM   #7
cookingguy
1979 FSJ Cherokee
Well that is true but I got the engine out of a 79 and the jeep is an 83. And the engine has to be newer than the jeep so I must do 84 waggy smog
Unread 02-06-2015, 04:27 PM   #8
SilverAnnCJ5
1979 CJ5
I brought the jeep into CA from another state with the 360 already in it so maybe that had something to do with it. I was nervous about the test. I didn't know if the engine change was possible. But I put all the smog stuff on, had the carb rebuilt, crossed my fingers and passed. Good luck with your test.
Unread 02-06-2015, 07:43 PM   #9
cookingguy
1979 FSJ Cherokee
That's the key it was not a ca jeep to begin with
