what paint for cj ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > what paint for cj ?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSteinjager TJ tube doorsAttention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONS
Unread 01-24-2014, 08:51 AM   #1
outdorzgy
1979 CJ7
what paint for cj ?
Still too cold to work on my cj but pretty stoked and trying to think ahead. Just wondering about paint? Pretty sure I want my jeep tangerine metallic and saw a complete urethane kit from the coating store. I like the durability and coverage of a urethane paint and would appreciate any imput that forum members were willing to share. Urethane is not set in stone but I do like the finished product. Thanks and can't wait to hear some opinions
outdorzgy is offline   Reply With Quote
Unread 01-24-2014, 10:06 AM   #2
dg6772
Sounds good to me...I did mine inn good ole enamel. Dark green metallic.
Here's mine
http://i976.photobucket.com/albums/a...psm8fdugtc.jpg
Dave in Muskegon using JeepForum
dg6772 is offline   Reply With Quote
Unread 01-24-2014, 10:40 AM   #3
HackFabrication
1976 CJ5
I'm going with a stock Jeep color: Natural Green Pearl. Base coat/clear coat.
"In the end...It's all Hack."
HackFabrication is offline   Reply With Quote
Unread 01-24-2014, 10:52 AM   #4
Renegade82
Renegade82's Avatar
1982 CJ7
I plan on using Dupont's ChromaBase / clear. I used it in 96 on it and it lasted well, still looking good in Oct 2011 when I tore it down. And most of the years it sat outside year round. Much better than the metal underneath it did!!
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (still in progress....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote
Unread 01-24-2014, 12:36 PM   #5
SouthernGypsy
1983 CJ7
Urethane based paints are the newer generation of paints and work great on things like Jeeps because it flexes with the body instead of cracking when the body shifts or flexes and it can take things like rock hits better where some paints chip. If they'd had urethane paints out when these old Jeeps was first made no doubt Jeep would have used them for such an application. You can get urethane based paints in any color to make your factory color or any color you want.
SouthernGypsy's current Jeeps:
1983 Jeep CJ-7 Limited 4.2L ~ Daily Driver, Prepping for a 2 month Tour of America Summer 2014.
More Mopar Muscle Cars, Grand Cherokees, Cherokees, and ATV's than I care to count!
SouthernGypsy is offline   Reply With Quote
Unread 01-24-2014, 04:10 PM   #6
outdorzgy
1979 CJ7
Thanks. Loving the been there done that info you get off this forum. It really helps to hopefully avoid a lot of mistakes. Thanks again.
Unread 01-24-2014, 04:41 PM   #7
seabass1858
CJ Literate
seabass1858's Avatar
1983 CJ7
Originally Posted by SouthernGypsy View Post
Urethane based paints are the newer generation of paints work great on things like Jeeps because it flexes with the body instead of cracking when the body shifts or flexes and it can take things like rock hits better where some paints chip.
this is what the body man is using on mine. doing base coat/clear coat almond beige and putting the renegade decals back on like original. Im trying to turn heads instead of stomachs at the sight of the ol cj7.
seabass1858 is offline   Reply With Quote
Unread 01-24-2014, 06:50 PM   #8
82JeepCJ7
1982 CJ7
Krylon.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote
Unread 01-25-2014, 02:34 PM   #9
strvger01
1966 CJ5
i like the satin paints lots. have that on my pu for the past 5 years and it has done really well. will be doing the same thing on my cj this coming summer. doesn't show near the dirt, scratches, etc. that high gloss paints allow to be seen.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline   Reply With Quote
Unread 01-25-2014, 03:46 PM   #10
Brewski
You can get the same satin finish with B/C system paints by using a flattening agent. Be sure to document precise parts agent to paint in the event you need to match for a repair.
Brewski is offline   Reply With Quote
Unread 01-25-2014, 05:36 PM   #11
ChrisCarlock
1982 CJ7
European clear is a really thick and pretty clearcoat. It always has the wet look.
ChrisCarlock is offline   Reply With Quote
Unread 01-26-2014, 10:05 AM   #12
strvger01
1966 CJ5
exactly. that's why it was just easier for me to use the satin paint to begin with. and i didn't even use a satin clear coat. still looks great.
Unread 01-27-2014, 06:39 AM   #13
AcidLamp
I rolled on some rustoleum satin. Looks just fine, takes a wax decently for a dull shine, and is simple and easy to touch up.
AcidLamp is offline   Reply With Quote
Unread 01-27-2014, 06:52 AM   #14
seabass1858
CJ Literate
1983 CJ7
that would be a neat pic to see
Unread 01-27-2014, 11:17 AM   #15
Gigemags05
1980 CJ7
I am using omni ss to paint my jeep this weekend. Been sanding, filling, sanding, sanding for a month.
Gigemags05 is offline   Reply With Quote
