What is need for this motor swap? - JeepForum.com
post #1 of 4 Old 06-27-2002, 07:59 AM Thread Starter
CJEli
Post What is need for this motor swap?
Hey Guys,
I have a 79 CJ7 with the 258 and the motor is getting tired. I am in the process of looking for an AMC 360 or a Chev 350 to put in. Besides the motor mount adapter kit, what else is needed for the conversion? I am going to stick with the stock 3 speed stick.
Thanks for your help,
-Eli
00 Yellow TJ Sport, Locked, on 35s
CJEli is offline
post #2 of 4 Old 06-27-2002, 09:36 AM
LS1CJ5
1979 CJ5
Post
I just did the LS1 swap. Bellhousing to go from the T150 to the 350. If you had the 4cyl 151 you could use it. They do sell bellhousings that can connect up to your clutch linkage. That's a good idea. The radaitor's in's and out's are a little further away than the Amc was. I ran Z28 electric fans then the stainless flex hose. I used 24" for the bottom line and 12" to the top. Ok the Chevy swap can snowball on you, but if you can get the motor Cheap and don't mind the work, go for it. That makes one more CJ on the road. which is a good thing.
Or the 360, which is a fine motor. Make sure you get all of the parts. That front cover can cost you 300. With the 360 you'll just need motor mounts. Maybe upgrade the radiator, exhaust also.
LM
1979 CJ5 LS1, NV4500
LS1CJ5 is offline
post #3 of 4 Old 06-27-2002, 04:34 PM
cjdriver
cjdriver's Avatar
Post
If you go with the 360 all you will need is the stock Jeep engine mounts as the bell housing is the same as the 258.
For the Chev you will need a bell housing adapter from someone like advance adapters and you will need the new motor mounts. You will also need some flexibel radiator hoses or a radiator designed for the conversion since the outlets are opposite the stock Jeep one. Mepco 4x4 sells exact replacements with the outlets in the right place in several sizes to meet your needs. I used to work there and they are real nice units. Call them at 1-800-388-5337. Or online at <a href="http://www.mepco4x4.com" target="_blank">www.mepco4x4.com</a>
Jim Sykes
motorsports photography
cjdriver is offline
post #4 of 4 Old 06-27-2002, 07:07 PM
NMullens
NMullens's Avatar
Post
There is a good article in this month's Jp Magazine. It talks about the stuff you dont think about when doing any swapping. Good Luck though.
Currently Jeepless - Previously owned 1983 SJ, 1979 CJ-7 and 1991 YJ
NMullens is offline
81 Cj7 Motor swap Dogfacedbeaver Jeep CJ Forum 0 09-16-2009 02:04 PM
Got the motor for the swap! scrible Jeep CJ Forum 12 10-31-2006 07:34 PM
CJ7 motor swap to a 350. 86cj7laredo Jeep CJ Forum 5 07-25-2006 12:12 PM
cj motor swap but what motor need help flip2spin Jeep CJ Forum 3 01-21-2004 07:11 AM
Motor Swap antman Jeep CJ Forum 1 08-09-2002 10:22 PM
