What motor is in my Jeep? Is this the right carb?? - JeepForum.com
post #1 of 7 Old 06-20-2008, 01:51 AM Thread Starter
jrb1449
1978 CJ5
1978 CJ5
Not sure on the engine size. Can't tell by the valve cover. It just says "Clifford 6=8". Can you help me? I have a Chilton and am trying to work on this thing but am not sure which motor size to go by.
Also what could make the pushrods pop out from under the rocker arms? (Or was the PO just absent minded?)
Is this even the stock motor for my jeep? Is it the right/stock carb? Sorry, I am a noob with Jeeps. I got it to run but it popped through the carb so I took the valve cover off and found two pushrods just chillin.
Thank a bunch guys,
Josh
Last edited by jrb1449; 06-20-2008 at 01:51 AM. Reason: edit: cant post pics as noob status....
jrb1449 is offline
post #2 of 7 Old 06-20-2008, 01:55 AM
OldSailor
1977 CJ7
Assuming that the engine is OEM: If it is an inline 6-culinder, it is a 4.2 liter (258 c.i.) engine. If it is a V-8 cylinder engine, it is a 304 c.i. (5.0 liter) engine. If it's a 4-cylinder engine, I don't know what the displacement is.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline
post #3 of 7 Old 06-20-2008, 02:04 AM
hextex
Cliffords' makes performace pars for AMC engines ranging from intake manifolds to valve covers to push rods to camshafts. There is really no telling what all could be in the engine.
hextex is offline
post #4 of 7 Old 06-20-2008, 02:07 AM Thread Starter
jrb1449
1978 CJ5
Damn. you Fellas are fast!!!
It is an inline 6. 1978 CJ5 lifted on 39.5's. (see last picture/link)
I was off looking for somewhere to upload pics so I can post them here.
AND THE NEW HOTNESS...... or hotmess....
jrb1449 is offline
post #5 of 7 Old 06-20-2008, 03:49 AM Thread Starter
jrb1449
1978 CJ5
Well, I put the pushrods back in place and retourqed the rocker arm bolts to 21ft lbs. Reinstalled and cleaned up valve cover, and re-installed carb. We will see i the morning if she runs a little better with all the valves working.
Next need to fix a brakeline, finish LED brakelight install, mount 3 row radiator from cherokee, check fluid and take her for a spin.
Pray for me!!!!
jrb1449 is offline
post #6 of 7 Old 06-20-2008, 06:00 AM
mcmud
1983 CJ8
Engine Codes
This should help you ,and others, identify engine codes.
http://www.amcrc.com/tech/engine.html
Edit, Carb is the Carter BBD. The lifters could be sticking or collapsed, but then never underestimate a PO.
mcmud is offline
post #7 of 7 Old 06-21-2008, 07:36 AM Thread Starter
jrb1449
1978 CJ5
well.... It runs like a champ!!! Looks like for one reason or another the PO just didn't put the pushrods under the rocker arms. Now that the valves all open and close it runs great!!
jrb1449 is offline
Carter 1Barrel carb ? For my 232 motor my old cj Jeep CJ Forum 6 11-01-2009 06:46 AM
Nutter bypass on carb without stepper motor? muddyjeepguy85 Jeep CJ Forum 2 10-15-2008 08:00 AM
Holley Carb: which one will fit my jeep? drunkenrich Jeep CJ Forum 5 02-26-2008 07:06 PM
jeep carb Wmasseyiv Jeep CJ Forum 8 03-21-2007 09:14 AM
carter carb without stepper motor? oldfrt47 Jeep CJ Forum 1 11-02-2003 04:24 AM
