What motor mounts should I buy for dropping in a sbc 350? - JeepForum.com
post #1 of 11 Old 01-24-2012, 02:10 PM Thread Starter
jason-cj5
1980 CJ5
I bought a sbc 350 out of a 95 silverado. What company of motor mounts should I get? I found 3 different companys, first is advance adapters which is cheapest, then novak which is in the middle, and m.o.r.e. which is the most expensive. Any info on these would help out a lot.
jason-cj5 is offline
post #2 of 11 Old 01-24-2012, 02:17 PM
DT5150
1983 CJ7
i used more's in mine. you have to consider your headers/manifolds when choosing motor mounts. your choice in mounts will often depend on which you are going to use; headers or manifolds. like i said, i have more mounts in mine, but i use shorty block hugger headers.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #3 of 11 Old 01-24-2012, 02:45 PM
rsg1963
1979 CJ7
Moor Bomb-Proof FTW. All motor mounts should be this good.
rsg1963 is offline
post #4 of 11 Old 01-24-2012, 04:39 PM
1971cj6man
I have used advance adapters on three different jeeps! Great mounts!!! Hands down the best! Don't go with headers stick to a ram horn manifold, which can be had cheaply... Under $40
HAVE FUN!
Two of my builds are threads here and both are using A.A. Mounts
1971cj6man is offline
post #5 of 11 Old 01-24-2012, 08:16 PM
mrmrezg
1982 CJ5
http://www.summitracing.com/parts/TRD-4563/
I just purchased a set of these for putting a 305 into my cj5. I work away from home so I have not put my hands on them yet but my wife says that they are very heavy. I can let you know more about them this weekend, after I get home.
mrmrezg is offline
post #6 of 11 Old 01-25-2012, 04:24 AM Thread Starter
jason-cj5
1980 CJ5
I'm probably going to run headers in my jeep, so out of those three which ones can I use?
post #7 of 11 Old 01-25-2012, 06:16 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
more
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #8 of 11 Old 01-25-2012, 06:23 AM
DT5150
1983 CJ7
x2. more's with shorty block huggers, or some rear dump style headers will work. i have the ceramic coated shortys from summit. very pleased with them so far, and half the price of the name brand headers.
DT5150 is offline
post #9 of 11 Old 01-25-2012, 11:06 AM
SleeperCJ
1983 CJ7
I used the novak weld in for my SBC install. lots of versatility in mounting location. cleared my manifolds and steering with no problem.
SleeperCJ is offline
post #10 of 11 Old 01-25-2012, 03:46 PM
southshore30
1982 CJ7
I used M.O.R.E. with Sanderson shorty block hugger headers and really liked them. Can't beat bolt in "bomb proof" motor mounts!! I drilled a extra hole and made the others slightly larger to upgrade to 3/8 bolts and opted not to do any welding. I had a 290 hp crate motor and am now building a 350+ hp motor to put in for this summer and am not worried one bit those mounts won't be up for my abuse!
Firefighters Jeep Club
SBC350,T-176,D-300,D44
southshore30 is offline
post #11 of 11 Old 05-04-2013, 09:17 PM
bods7
1983 CJ7
Chevy V8 engine mounts
Hey South Shore,
Why did you drill an extra hole? Did you have too or just wnat to? How many holes are in the MORE mounts that bolt to stock frame without modification.
I am trying to figure what motor mounts to buy for my 350. I have an NV4500 behind it. I don't want weld in mounts. I trying to find the best bolt mounts I can find that will bolt in without having to change anything else. I also don't want to cut the front differential stop off the frame on passenger side.
Will the MORE engine mounts work with no modification?
bods7 is offline
Poly or rubber motor mounts?...whatta bout torsion rubber mounts too? Collard Green Jeep CJ Forum 2 06-14-2011 07:56 PM
MORE motor mounts 92XJT Jeep CJ Forum 2 11-24-2009 04:50 AM
Motor mounts shadoow Jeep CJ Forum 3 12-18-2006 10:49 AM
Motor mounts CJ7 - 360 Whistler Jeep CJ Forum 5 10-12-2006 07:06 PM
84 CJ7 258 - Motor mounts. jooper84 Jeep CJ Forum 2 08-21-2006 08:51 AM
