What is this module for - JeepForum.com
post #1 of 7 Old 07-07-2010, 05:01 PM Thread Starter
weprint
On my 81 CJ7 with a 258 engine, there is a module with nine wires coming out. It is located directly opposite the alternator on the passenger side wheel well. The wiring diagram I have does not indicate this part. Can someone tell me what is is and its purpose? Thanks.
weprint is offline
post #2 of 7 Old 07-07-2010, 05:08 PM
MoC
Picture please.
MoC is offline
post #3 of 7 Old 07-07-2010, 05:58 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Is this what you're seeing?
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #4 of 7 Old 07-07-2010, 08:51 PM
mcmud
1983 CJ8
That would be the first generation MCU used in the 49 state '81 & '82 build years.
It is or was used to control the fuel feed back system by taking readings from the O2 sensor and controlling the BBD stepper pins and the sol-vac actuator.
mcmud is offline
post #5 of 7 Old 07-07-2010, 09:57 PM Thread Starter
weprint
No, it's not the starter relay but it is to the right of the relay in your picture. I believe it is the MCU as stated in another reply. Thanks for the reply.
weprint is offline
post #6 of 7 Old 07-07-2010, 10:03 PM Thread Starter
weprint
Thank you. Since I have a Motorcraft 2100 carb, I assume that this module isn't doing anything and could be removed along with its associated wiring. Is this correct?
weprint is offline
post #7 of 7 Old 07-07-2010, 10:31 PM
mcmud
1983 CJ8
Yes sir, you can unplug it or follow the wires to snip and remove them from the harness.
mcmud is offline
ICM module mjeckell Jeep CJ Forum 14 04-27-2014 08:22 PM
MSD cdi module (which one?) kmm Jeep CJ Forum 17 06-17-2010 05:35 AM
258 DUI replacment module petey156 Jeep CJ Forum 2 06-04-2009 02:16 PM
Cj8 Module JEEPPARTSGUY Jeep CJ Forum 3 09-07-2006 09:21 AM
Ign module CJ-5 Jeep CJ Forum 20 09-28-2004 06:43 AM
