What lift is needed to fit 36-38 inch tires a 1980 cj 7? - JeepForum.com
post #1 of 6 Old 01-16-2003, 05:10 PM Thread Starter
jeepcj7
What lift is needed to fit 36-38 inch tires a 1980 cj 7? Would a 4 inch suspention, 2 body and a spring-over-axle, work? How much do u think it would cost?
jeepcj7 is offline
post #2 of 6 Old 01-16-2003, 09:28 PM
cj5mudman4x4
I am pretty sure that would take care of ur tires.. all together u have like 9 or 10" of lift.. if that wont do it i dont know what will.. u might not even need the spring over..
a rough guess would be around 500-600.. but i duno...
Suspension Lift 4"- $400
Spring Over if done right, 4" or more- $150
Body Lift 2"- $75-100
hope that helps
check out www.off-road.com
this site will tell u how much lift for what size tire..
1973 CJ5
258ci I6 rebuilt. bored .40
Painless wiring harness
INDEPENDENT OFFROAD member Bowling Green, Ky
cj5mudman4x4 is offline
post #3 of 6 Old 01-16-2003, 09:32 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
SOA and 2.5" lift is sufficient - several of my friends are setup this way and it works fine with 37" tires.
Steve
OldJeepguy is offline
post #4 of 6 Old 01-16-2003, 11:23 PM
mad_scientist
about 7-9" of lift is usually adequate.
a large leaf pack from national spring can get all of the lift for you in springs, or you can opt for variace combinations to get it
slightly longer shackles if you go with a high arch lift... this will let the suspension work better (probably consult the maker of your springs for their suggestion on added length).
spring over and body lift can get the rest of the clearance you need
mad_scientist is offline
post #5 of 6 Old 01-16-2003, 11:42 PM
CSP
OldJeepguy has the right answer. You add 4" to a spring over and you're sitting in the 8-9" of lift range. Way to high to be comfortable and much higher than needed for 38's. If you have slight rubbing with that combo go with fender trimming and TJ flares or 1" of body lift.
cj5mudman your $150 estimate for spring over is a bit too low for one "done right". Your estimates also didn't include longer driveshafts, brake lines, and steering conversions needed with as much lift as you propose.
CSP is offline
post #6 of 6 Old 01-18-2003, 07:42 PM
RockJeep
Motobilt.com
RockJeep's Avatar
spring over, cut your fenders out or remove completely. I fit my 38 tsl's this way!
later
bob
http://rockjeep.alloffroad.com/photo6.html
1998 Jeep TJ on 37's, locked, long armed etc
Sales Manager at
RockJeep is offline
35 inch tires with 4inch lift? Demo Jeep CJ Forum 10 06-30-2009 08:42 AM
4 inch Rough Country Lift on 28 inch tires CrazyFlippinCJ7 Jeep CJ Forum 16 03-02-2008 03:09 PM
Lift to clear 35 Inch tires :rtft: sbestmann Jeep CJ Forum 19 01-14-2004 12:59 AM
Does anyone have any pics of a jeep with a 6 inch or more lift and 35+ inch tires? jeepcj7 Jeep CJ Forum 10 03-23-2003 09:39 AM
Is there a 6 inch lift out there, for a cj 7 1980? What is the best overall lift? jeepcj7 Jeep CJ Forum 13 01-18-2003 10:46 AM
