What kind of drag link is this? - JeepForum.com
post #1 of 2 Old 08-15-2013, 10:52 PM Thread Starter
Halfmoon
I'm new to all this but didn't the stock drag links have adjustments on both sides? When looking for play in the steering system, the drag link at the pitman arm seems to have the most. Is my only option to replace the entire drag link? The bolt wobbles back and forth before the drag link moves.
Halfmoon is offline
post #2 of 2 Old 08-15-2013, 11:29 PM
WSS
WSS's Avatar
1972 CJ5
If you can see the thread with the nut moving, then your pitman arm and tierod are probably bad. You may be able to tighten the nut to see if it will suck up in the tapered slot and cure the wiggling. It has been a while since I have worked on a scout, but it resembles a scout arm.
A few months ago, I overhauled my steering stuff and the cost was not too bad. I did a tre flip to eliminate the drop pitman arm (plus get them up a little higher) and built a tie rod and draglinl out of 1-1/4"x .120 DOM and some bigger tres off ebay for about $150. I did already have a stock pitman arm, that saved a little $$.
If you are a Purist, don't click here:
My CJ5 Build and fun stuff:
WSS is offline
