what is a jumper wire to use to check the check engine light codes. - JeepForum.com
post #1 of 4 Old 07-09-2008, 04:59 PM Thread Starter
vilentj
my 1996 jeep cherokee check engine light came on and it started to act up and the engine started cutting out like its not getting fed gass..
in my wireing manual it tells me too get the flashing thing to work i have to "connect the trouble code test terminals 6 and 7 with a jumper wire" sept i dont know what a jumper wire is. can someone help me plz
vilentj is offline
post #2 of 4 Old 07-09-2008, 05:05 PM
happydog
This is the wrong forum. Stock CJ's do not have "check engine" lights.
"I don't do things, I give advice." by an old geezer in the movie "Milagro Beanfield War"
"After all, it is the slave who thinks himself a free man who makes the best slave." (Unknown)
“A closed mind is like a closed book; just a block of wood”. Chinese Proverb
happydog is offline
post #3 of 4 Old 07-09-2008, 05:23 PM
bdmonist
WTF is that?
bdmonist's Avatar
A jumper wire is just a wire that connects terminal 6 and 7. Grab some scrap wire, but you Are in the wrong Forum.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #4 of 4 Old 07-09-2008, 09:29 PM
Wolf359
WOLF359
Wolf359's Avatar
I would just go to AUTOZONE and borrow a code reader. Plug it into the OBDII terminal to run a dignostic. You might be able to reset the light but it'll turn on again if you don't fix the problem.
Wolf359 is offline
Howell TBI Install: Tach and "Check Engine Light" question jatepper Jeep CJ Forum 10 07-19-2009 10:07 AM
Check out my new engine BioTex Jeep CJ Forum 15 03-07-2009 07:20 AM
Check engine light Carmell CJ Jeep CJ Forum 3 03-03-2007 04:05 PM
Mopar Check Engine Light (CA) Curly Jeep CJ Forum 3 10-30-2005 12:38 PM
