What jeep do I have? - JeepForum.com
post #1 of 10 Old 05-06-2013, 10:01 AM Thread Starter
brycez28
Last week I bought a jeep frame with suspension, axles, wheels and steering gear box. He called it 1960 Willy's Jeep, but what model would this actually be? It has Dana 25 front axle and Dana 44 rear axle and a short wheel base. That is all I know about it. Any help would be appreciated!
brycez28 is offline
post #2 of 10 Old 05-06-2013, 10:17 AM
RamblingCJ
Most likely it's a CJ-3b. Those axles match what came on the 1960 model.
RamblingCJ is offline
post #3 of 10 Old 05-06-2013, 10:45 AM Thread Starter
brycez28
Thank you. What does the "b" stand for?
brycez28 is offline
post #4 of 10 Old 05-06-2013, 11:07 AM
82JeepCJ7
1982 CJ7
Does it look like this?
The B is just the next sequential model number. The previous model was the CJ-3A. When Willy's put the F-134 (Overhead valves) motor in, they need to do a "hoodectomy" to make room. That's why there is a spacer section in the body cowling and and the higher hood.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #5 of 10 Old 05-06-2013, 11:08 AM
WindKnot
1977 CJ7
The 3A and the 3B had some differences. The 3B had a different engine which required raising the hood and placing a taller grill. The CJ (Civilian Jeep) 3A was produced by Willys (pronounced Willis, not Willees). The CJ3B was built by Kaiser after Willys was sold to them.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #6 of 10 Old 05-06-2013, 11:16 AM Thread Starter
brycez28
I don't have the body, just the frame.
brycez28 is offline
post #7 of 10 Old 05-06-2013, 11:21 AM
82JeepCJ7
1982 CJ7
The only true way is to decode the VIN number. Look on top of the frame by the left front shock mount. There should be VIN stamped into the frame. The frames were pretty much the same despite the model. I know its not a M38 (no shackle reversal in the front).
post #8 of 10 Old 05-09-2013, 06:53 PM
brownbagg
1930 MK Compass
you got everything that people usually throw away when they upgrade to anything
brownbagg is offline
post #9 of 10 Old 05-09-2013, 07:00 PM
skizriz
1978 CJ7
Always helpful information, as usual.
skizriz is online now
post #10 of 10 Old 05-10-2013, 09:09 AM Thread Starter
brycez28
For what I'm planning on doing, this will suffice.
brycez28 is offline
