What inch lift? (pics) - JeepForum.com
post #1 of 33 Old 04-13-2012, 03:45 PM Thread Starter
Turtle71
1983 CJ7
Correcting lift and OME YJ conversion (pics)
When I bought the Jeep, it had a shackle reversal, taller shackles and Rancho shocks and steering stabilizer. Not sure if the leaf springs are Ranchos or not.
Front Drivers side with Shackle reversal:
Rear drivers side:
Trying to figure out how much lift it has so I can replace the worn out shocks with cheapies to help with the horrible ride until i can afford and have the time to install an Old Man Emu lift. So I took some measurements from the bottom edge of the body to the ground. Heres what I came up with.
Behind front drivers wheel: 21.25" Passenger side: 21.50"
In front of rear drivers wheel: 22.25" Passenger side: 22.75"
Rear drivers side:25.5" Passenger side: 26"
So can anyone tell me how much it has over stock or what typical stock measurements are?
Or maybe someone has something close to these measurements???
My 83 CJ7 Build:
Turtle71 is offline
post #2 of 33 Old 04-13-2012, 03:52 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Talk about a home brew contraption!
Save your money and do it right all at the same time.
Those cheap shocks probably won't change your ride quality, Although they might make it worse than it is now.
If you like the SRS, you might cut that stuff off and go with a M.O.R.E. Kit designed for YJ style springs that OME offers.
LT1CJ7 is offline
post #3 of 33 Old 04-13-2012, 04:26 PM Thread Starter
Turtle71
1983 CJ7
For some reason my post was only showing partially. Fixed now. What would you say is home brew....shackles?
My 83 CJ7 Build:
Turtle71 is offline
post #4 of 33 Old 04-13-2012, 04:32 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
That SRS = shackle reversal system is 100% home brew and not too safe looking.
The shackles are monsters and I would guess you have a handfull keeping it controlled.
The bolts on the rear spring hangers are non existent and welded on.
And the dual stabilizer is just masking handling problems.
I'd take a guess the springs are factory stock originals.
LT1CJ7 is offline
post #5 of 33 Old 04-13-2012, 04:51 PM Thread Starter
Turtle71
1983 CJ7
Woah! Surpised I never noticed the rear shackle was welded on....guess I just focused on the gigantic shackle itself.
Any estimates on lift?
My 83 CJ7 Build:
Turtle71 is offline
post #6 of 33 Old 04-13-2012, 04:52 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
X2. rip it all off and do it right from scratch.
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #7 of 33 Old 04-13-2012, 05:14 PM Thread Starter
Turtle71
1983 CJ7
Agreed. Dang, I thought I was going to be able to drive it a bit. It actually is not too bad on handling. I expected it to wander much more.
My 83 CJ7 Build:
Turtle71 is offline
post #8 of 33 Old 04-13-2012, 05:24 PM
Erik719
1983 CJ7
Shocks are on upside down too. Seem to remember this was popular back in the late '80s.
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline
post #9 of 33 Old 04-13-2012, 05:39 PM
RobsCrawlin7
no balls
Originally Posted by Turtle71 View Post
Agreed. Damn, I thought I was going to be able to drive it a bit. It actually is not too bad on handling. I expected it to wander much more.
you can if you want, at your own risk. God knows ive driven my CJ in less that "perfect" condition. right now i have no rear shocks lol
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #10 of 33 Old 04-13-2012, 06:03 PM Thread Starter
Turtle71
1983 CJ7
Yeah...I probably just need to bite the bullet and start piecing together an 2.5" OME YJ conversion lift. Just need to figure what duty springs etc.
My 83 CJ7 Build:
Turtle71 is offline
post #11 of 33 Old 04-13-2012, 06:51 PM
RenoF250
I don't see anything wrong with the SRS in the front. The rear needs help though. The frame looks questionable and probably nearly rusted through. Also those rear shackles are ridiculous.
RenoF250 is offline
post #12 of 33 Old 04-13-2012, 07:59 PM
pman
Jeez. That rear shackle looks like the ladder to my son's bunk bed. I agree; start from scratch. Yikes.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #13 of 33 Old 04-13-2012, 08:11 PM
Shiftace
1977 CJ5
Have to agree, go whole hog when you are ready to. Until then, just be aware of the situation when driving it.
Originally Posted by gpets View Post
...it is perfectly acceptable to take a sawzall to anything you can't figure out, that is how we all learn.
Shiftace is offline
post #14 of 33 Old 04-13-2012, 08:31 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Originally Posted by RenoF250 View Post
I don't see anything wrong with the SRS in the front. .
LT1CJ7 is offline
post #15 of 33 Old 04-13-2012, 09:48 PM
Skerr
Somebody explain what I'm llooking at in the first pic. Is the frame bent down? And I have to agree with LT1 about the bolt being nonexistent in that second pic. It doesn't look strong at all, or even on the same plane. You know better than anyone, Turtle, but I personally would not drive it like that. I think you could fix the second pic pretty easy with the correct shanckle hanger. That would be the "safe" fix. If the frame is bent down in the first pic I would bend it back and fishplate it. Get some smaller shackles and keep your springs until you're ready for your major plan, but I would be concerned about safety first. I don't want to read about you!
Kerrdog
Go Fish! <*////><
Skerr is offline
Switching my 3 inch body lift with a 1 inch - need advice MemphisCJ7 Jeep CJ Forum 3 03-31-2011 09:55 AM
1 inch body lift and 3/4 inch shackle lift? bucs1fan Jeep CJ Forum 6 09-29-2009 12:21 PM
4 inch Rough Country Lift on 28 inch tires CrazyFlippinCJ7 Jeep CJ Forum 16 03-02-2008 02:09 PM
pics of 21/2 inch lift request dblock16 Jeep CJ Forum 6 10-04-2007 03:55 PM
Does anyone have any pics of a jeep with a 6 inch or more lift and 35+ inch tires? jeepcj7 Jeep CJ Forum 10 03-23-2003 08:39 AM
