What gears should I go with??? - JeepForum.com
post #1 of 3 Old 05-22-2003, 05:31 PM Thread Starter
Yellow Fever
Yellow Fever's Avatar
Hi Everyone,
I just purchased a '85 CJ7 with 6 cyl, and I was wondering if anyone know what my gear ratio is, or how do I go about finding out. I'm going to get a BDS lift, so I can fit 33's underneath. This will be my daily drive on the highway, so I'll need some speed too. What gear ratio would you guys recommond? Also, will YJ half doors fit on a CJ7?
Thanks,
Yellow Fever
95 YJ - 4 Banger
Pro Comp 4" (What a mistake)
BFG 33 A/T with Black Rock Crawler
4:56 Gear
85 CJ7 - 6 Cyl
Currently being Restored
Yellow Fever is offline
post #2 of 3 Old 05-22-2003, 06:51 PM
fuzz401
1978 CJ7
should be numbers on the tag on the rear with the teeth count or jack it up mark the drive shaft and the tire turn the drive shaft 1 turn and count how much the tire turns it will give you a close gear range as far as gearing get gears the will keep you in the stock range with the 33 tires
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 3 Old 05-23-2003, 02:30 AM
Sandman74
good rule of thumb is tire height in inches times .12
33 inch tires x .12 = 3.96
Youth and talent is no replacement for age and treachery.
Sandman74 is offline
can i run 35s on my cj5 and what gears should i run eckley25 Jeep CJ Forum 7 09-15-2008 09:09 AM
What gears should I buy? nichols077 Jeep CJ Forum 12 05-20-2008 04:31 PM
Gears spk454 Jeep CJ Forum 5 04-12-2008 08:20 PM
Help with gears hardee81cj7 Jeep CJ Forum 6 10-25-2005 01:52 PM
If gears are shot, can you use 4wd gears? cinnamonbelle Jeep CJ Forum 2 03-24-2003 10:44 PM
