what gears came factory? - JeepForum.com
post #1 of 12 Old 12-01-2013, 06:54 PM Thread Starter
bubbz
1980 CJ5
I know the only positive way to tell is pop a cover, but that being said, does anyone know what gears they put in most 1980 cj5 with gm 151, sr4, dana 300 combo. My jeep has 31/10.50/15 on it and not sure yet how it even does with them until i get my new exhaust manifold.
bubbz is offline
post #2 of 12 Old 12-01-2013, 07:49 PM
BagusJeep
1981 CJ7
2.73 AA or D, 3.31 BB or B, 3.73 GG or H
If you want to have a stab at it in 2 minutes crawl under the back end and look at that AMC20. to the left of the diff cover you should find one or letters stamped on at the factory. I have given the letters above for the non-locking diffs.
The 31s are only slightly larger than stock which were about 29". From memory that is 7% difference in circumference, which you will not notice. Whilst a low powered unit it is a light vehicle, if not blinged with winches and heavy bumpers and wheels.
The problem is that the 2.73 were already a poor choice on stock wheels.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 12 Old 12-01-2013, 07:51 PM
CSP
The stamp is to the right of the diff cover, looking at it from behind.
CSP is offline
post #4 of 12 Old 12-02-2013, 09:48 AM
wm69
With a 4banger if you're lucky you'll have 4.10's or at least 3.73's. Look here.....
wm69 is offline
post #5 of 12 Old 12-02-2013, 04:46 PM Thread Starter
bubbz
1980 CJ5
thanks so much for the info.. I just crawled under there and found it. It has an "A" stamped on it.. now just to find the meaning of "A"... lol and thanks again for all the quick reply and the pics...
bubbz is offline
post #6 of 12 Old 12-02-2013, 04:52 PM Thread Starter
bubbz
1980 CJ5
I think it`s 3.54 correct me if I`m wrong..
bubbz is offline
post #7 of 12 Old 12-02-2013, 04:54 PM
ADDZ71
1979 CJ7
3.54 non locking variety
ADDZ71 is offline
post #8 of 12 Old 12-02-2013, 04:54 PM Thread Starter
bubbz
1980 CJ5
AMC
[edit]ID
AMC axle codes are stamped on the differential casting between the cover and the tube weld hole on the passenger side) beginning in 1970 for the AMC 20 series rearend, 1972 for the AMC 15 series. First four letters/ratios are 1970 rear axle codes stamped on the differential housing cover flange at about 3 o'clock:
A = 3.54:1 B = 3.15:1 C = 2.87:1 D = 3.91:1 E = 3.58 (12/43) F = 3.08 (13/40) G = 3.31 (13/43) H = 2.73 (15/41) J = 2.37 (19/45)
The 15 series had 10 bolt oval cover with drain plug center right.
[edit]15 series rearend
The AMC 15 series rearend has a 7-9/16" ring gear. It was used in 1965 and earlier models with 196 ci or 199 ci inline 6 engines. The small cars (cars other than those listed below as "big car") used the AMC 15 rearend with inline 6 engines, AMC 20 rearend was used with V8 engines. The AMC 20 rearend could be ordered in fleet cars with inline 6 engines.
[edit]20 series rearend
The big cars (Ambassador, Classic, Rebel, Matador and Marlin) used the AMC 20 rearend with 232 ci inline 6 and bigger engines.
The series 20 was used in Jeeps as well as AMC passenger cars. A Jeep 20 series rearend would have a 5 on 5" bolt pattern. Passenger cars used the 5 on 4-1/2" wheel bolt pattern.
bubbz is offline
post #9 of 12 Old 12-02-2013, 05:02 PM
lucdog
lucdog's Avatar
1980 CJ5
This might be easier to read.
Note there are differences between wide and narrow trac AMC 20's
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #10 of 12 Old 12-02-2013, 07:45 PM
CSP
CJ5 = narrow track, so this one has the standard 3.54s. The 4-cyl had 4.10s as an option.
CSP is offline
post #11 of 12 Old 12-02-2013, 09:07 PM
Spieg8
1984 CJ8
Given that your Jeep is 33 years old and also that CJ owners tent to tinker/upgrade/swap more than most, it's probably about a 50/50 chance that you still have the original gears. Before making a decision about a possible gear change, I'd open the case and verify what's in there (it's a good idea to do a periodic inspection anyway).
Spieg8 is online now
post #12 of 12 Old 12-02-2013, 09:22 PM Thread Starter
bubbz
1980 CJ5
For sure.. I plan on opening up both for inspection and change fluid. PO broke a bolt on the rear cover and it has been leaking fluid past his patch work, aka gasket maker glob,.. Got to get all that taken care of as well... Thanks for all the info. Just got the exhaust manifold in today. if i can get a windshield for it ,and all the fluids to stay where they belong, I can give her a road test.
bubbz is offline
