What engines have you put in your CJs? - JeepForum.com
post #1 of 44 Old 07-27-2004, 03:55 PM Thread Starter
kdouble99
Just curious. This all came about when someone told me they put a dodge neon engine in theirs. Or, at least that whey he told me.
kdouble99 is offline
post #2 of 44 Old 07-27-2004, 04:03 PM
rukkus0o
rukkus0o's Avatar
Hey,
Just got done installing a small block chevy into my 74 setup this past sunday. I used a noval adapter kit and motor mounts and everything went smoothly. A bit more welding and she'll be ready to roll
http://www.lewlz.msshost.com/rukkus/DSC00170.JPG
74 CJ5 - 4" Lift, t-18 tranny, Dana 20, sb chevy 305, Dana 44 rear, Dana 20 Front
rukkus0o is offline
post #3 of 44 Old 07-27-2004, 08:27 PM
xoolinzyoox
xoolinzyoox's Avatar
350 SB Jasper
xoolinzyoox is offline
post #4 of 44 Old 07-28-2004, 02:41 AM
paulzwieg
paulzwieg's Avatar
AMC 360 4 barrel for now.
04 Rubicon four sale
05 LJ Rubicon the new toy
CJ of the Month Jan. 2010
paulzwieg is offline
post #5 of 44 Old 07-28-2004, 09:04 AM Thread Starter
kdouble99
I was thinking of a 'simple' 4.0 swap, well, actually have my mechanic friend do it, and buy him lots of beer.
post #6 of 44 Old 07-28-2004, 09:06 AM
djfuzzy
I am looking forward to a 302 swap next summer.
USMC 2006-Present
2000 TJ - some stuff
djfuzzy is offline
post #7 of 44 Old 07-28-2004, 06:39 PM
181jeep
I'll bet that neon jeep is a real fireball................
JB
1960 cj5 gm181 large port 4 cyl., sm465/model18t-case warn od, 5.38's d44 rear truetrac,model 27 front powerlock, bridgestone m/t 30x9.50x15
181jeep is offline
post #8 of 44 Old 07-29-2004, 06:48 AM
fuzz401
1978 CJ7
304 factory then AMC 360 now AMC 401
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #9 of 44 Old 07-29-2004, 09:04 AM
roxorjeeper
roxorjeeper's Avatar
dodge neon swap?
thats funny, cause we were actually looking into the neon head and performance parts to try a nd pep up the 2.5, the neon is a 2.4 we figured they were the same block so the parts would also be universal/interchangable.
Eat, Sleep, Drink and Bleed JEEP.[QUOTE]
Redneck Jeep Club Member#21
roxorjeeper is offline
post #10 of 44 Old 07-29-2004, 10:47 AM
SpiffBoy
That's a negitive, ghostrider, the pattern is full.
Neon is a 2.0
The 2.4 is a 1" larger deck height. Bore on the pistons is the same.
The Dodge truck 2.5 is a diffrent beast.
The 2.0 and 2.4 can swap heads. Base neon (from 95-now) offered a SOHC head. From 95-99 you could find a DOHC head. In 00-now a SOHC Magnum head was offered that has larger exahust ports. Starting on 03, the SRT was made with the 2.4 Turbo that's also found in the PT cruiser. This is about the same DOHC design as the 2.0 DOHC and the 2.4 DOHC (that can be found in the stratus, PT and minivans in NA form) Good luck finding any SRT/Turbo PT parts in a junkyard. Neon people tend to snap that up super quick.
The dodge 2.5 is closer kin to the 2.2 of the 80's. If you find an old turbo 2.2 or 2.5, that would be a better pull for performance parts.
The 2.5 used in the dakotas and such was put into use around 1995. This is an AMC design. Far diffrent from the neon 2.0
If you have any more information on the neon/cj swap, pass it my way. I got a spare engine and I'm almost crazy enough to do something like that.
SpiffBoy is offline
post #11 of 44 Old 07-29-2004, 10:47 AM Thread Starter
kdouble99
The neon engine is probably about the same HP as the 258 and is fuel injected and much better MPG. But...
Would it even work? How would it mate up to the tranny?
post #12 of 44 Old 07-29-2004, 07:22 PM
OL YELLAH
OL YELLAH's Avatar
Yeah, with about half the torque...and what little it has in all the wrong places. It'd be like driving around with a Singer sowing machine under the hood.
1979 Jeep CJ-5; 1972 258 (Pacesetter Header, Weber Carb, Wrangler Aluminum Intake, 2.5" Exhaust Straight Through w/ Thrush Mufflers); 2.5" BDS Lift; 1" Daystar Body Lift, Herculiner; RJS Belts; 33" Interco Trxus M/T Tires; Xtreme Alloy Wheels; 2.5" Perfomance Wheel Spacers; TFI Upgrade.
OL YELLAH is offline
post #13 of 44 Old 07-29-2004, 09:50 PM
Hoxviii
fuzzy, why not just go straight to a 351W? They fit in the same hole. . . 351 is about an inch taller and wider than a 302.
Justin
I don't do Jeeps, but i'm here to help.
Remember, anywhere a car can go a 4x can go, only slower and more deliberately. The ONLY advantage of a 4x is to be able to go where the car can't.
Hoxviii is offline
post #14 of 44 Old 07-29-2004, 11:12 PM
djfuzzy
Justin
302 Free from dad = $0
351W from wherever = some amount of money I don't have to fork out.
USMC 2006-Present
djfuzzy is offline
post #15 of 44 Old 07-29-2004, 11:19 PM
Hoxviii
Good call.
Justin
Hoxviii is offline
Let's See Those Painted Engines... poppatello Jeep CJ Forum 198 04-27-2017 12:20 PM
what engines will fit in a cj5 (82) Beninpcb Jeep CJ Forum 6 06-07-2009 03:06 PM
Which engines interchange? Hillbillyd Jeep CJ Forum 6 02-23-2008 09:15 AM
ATK Engines?? Vinnyl32 Jeep CJ Forum 5 08-16-2005 04:10 AM
Any CJ-3B used engines for sale??? Foshigity2017 Jeep CJ Forum 0 10-24-2004 05:12 PM
