What Engines directly bolt up to The TH400 Transmission? - JeepForum.com
post #1 of 17 Old 02-03-2010, 08:25 PM Thread Starter
CherryCj7
1979 CJ7
I was wondering what engines can directly bolt up to the TH400 Transmission besides the AMC engines. I was looking to go for fuel injection. I heard that the 305 may be a direct bolt on. is this true? Any suggestions for the fuel injection and direct bolt on?? Any Six Cylinders, smaller V8's...? thanks - CherryCj7
CherryCj7 is offline
post #2 of 17 Old 02-03-2010, 08:30 PM
JimNut
Pretty sure AMC engines and the Chevy engines have different bolt patterns.. I believe AMC used an adapter plate on the earlier models that came with the TH400 but later on had a completely different case.
If your using a standard TH400 from GM some engines that will work are:
4.3 v6
305 v8
327 v8
350 v8
400 small block v8
I'm sure there are more but that is a short list. Pretty much any small block v8 from Chevy will bolt up.
Build it, Wheel it, Break it, Fix it and Repeat!
JimNut is offline
post #3 of 17 Old 02-03-2010, 08:31 PM
illinicj
1979 CJ7
The case used for jeep TH400s is different than the regular GM case. You'll need an adapter to bolt it to something other than AMC. Check out novak's website.
illinicj is offline
post #4 of 17 Old 02-03-2010, 08:31 PM
bigredisb
1979 CJ7
As far as I know its only AMC engines that will mate to the TH400 that came behind AMC's. The bell housing is specifically cast for the AMC. GM also has the TH400 but the bell housing is different. You can swap the shafts between two transmissions to still utilize the Q trac with a small block chevy but it requires a complete trans rebuild to do so or the adapter as mentioned above. Someone will chime in on info to adapt a TBI (several people call it junk yard efi) to the AMC.
1979 CJ7 aka "Christine" Build Thread:
2013 Rubicon Unlimited build thread:
bigredisb is offline
post #5 of 17 Old 02-03-2010, 10:53 PM
1986cj
And if you are looking for a th400 for a Chevy not all GM TH400s are the same say a Buick or Olds TH400 will not bolt up to a sbc
1986cj is offline
post #6 of 17 Old 02-04-2010, 08:02 AM
JeepHammer
Running On Empty...
1973 CJ5
Depends on what version of the transmission CASE you have.
The internals are all mostly the same, it's the case that has been made in several different versions.
There is the B.O.P.. bell housing/bolt pattern,
Meaning it will bolt up to Buick, Oldsmobile, Pontiac,
There is the 'Chevy' case that will bolt directly up to any standard Chevrolet engine, I-4, I-6, V-6 or V-8, doesn't matter...
There is the AMC/Jeep version that will bolt up to any of the standard I-6 or V-8 AMC engines.
When anyone starts talking about THM-350 transmissions,
Then you are restricted to about EVERY GM ENGINE ever made from about '85 back to about '45 or so.
There weren't any THM 350 cases made to work with AMC engines, but you can buy an adapter if you just MUST use an AMC engine.
If you are considering a Chevy engine,
Then consider the 700R-4 or it's electronic counterpart, 4L60E over a THM-350...
You get a stronger transmission,
Deeper first gear,
And you get overdrive on the big end.
Too bad AMC/Jeep never used a 700R-4 behind an AMC engine, that would be a nice arrangment to have with factory parts.
Other transmissions from the AMC factory include Torque Flight A-727, just as seriously strong as the THM-400,
The down sized and weight TF A-999, were both made with cases that will bolt up directly to an AMC/Jeep engine.
Anyone that craps on either one of these choices has never worked in a transmission rebuild shop!
These are TOUGH transmissions,
The TF A-727 is just as tough, maybe more so, than the ford C-6 and just as tough at the THM-400.
The TF A-999 is just as tough as any of the THM-350 transmission, and more fuel efficient to boot!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #7 of 17 Old 02-04-2010, 09:46 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
Just curious, what is a THM-350 transmission?
Is it the same as the TH-350?
2Xtreme is offline
post #8 of 17 Old 02-04-2010, 10:01 AM
CSP
Yes, same thing. Turbo Hydramatic
CSP is offline
post #9 of 17 Old 02-04-2010, 12:27 PM
iagmc
1974 CJ5
THM was metric
Th is standard
The amc t400 also uses adaptors to the engine.
If you look at the fallowing pictures, it has all parts needed!
http://iagmc.shutterfly.com/auto
Most people don't see the light till they feel the heat.
iagmc is offline
post #10 of 17 Old 02-04-2010, 12:51 PM
CSP
Depends on what year the TH400 is. The first run had the adapter shown in your pictures and the pattern was the Buick nailhead to AMC. The next run (starting in '72?) used no adapter and had the AMC pattern in the transmission case.
CSP is offline
post #11 of 17 Old 02-04-2010, 02:27 PM
iagmc
1974 CJ5
This was on a 73.
I can not speak for any newer. From others I have spoke to, these parts were missing when the bought theirs and were needed. They were using it on late 70s. mine are all older than that.
iagmc is offline
post #12 of 17 Old 02-04-2010, 02:32 PM
CSP
How many "others"?
My '76 Cherokee had no adapter between the tranny bell and the engine block.
I'm sure someone else will chime in with the exact year they went from a nailhead Buick pattern with an adapter to an AMC pattern.
CSP is offline
post #13 of 17 Old 02-04-2010, 02:56 PM
iagmc
1974 CJ5
these parts were missing when they bought theirs
Did I say anywhere or implied that it was factory? 76 very well could have been a different trans.
Amc did have contracts and still bought what they could afford. I have seen strange things on Jeeps.
Willys, Kiser, AMC, Mopers (1st years) all had one thing in common, they all used the previous owners left overs. When AMC took over they changed things twice before they decided on a platform. hence all parts on 76 and newer mostly (I use losely) interchange. The year means almost nothing in the 70s changed suppliers so much and took leftover parts to next years run.
I will say that the 76 in the cherokee prob had the d300? this has the d20, d300 might be a good indicator that it would not need the adapter. I don't know for sure, it is newer than any of our stuff.
Long story short. AMC T400 were not all the same. Check before you buy.
iagmc is offline
post #14 of 17 Old 02-04-2010, 03:10 PM
CSP
Jeep D300 was only used in CJ's. My '76 had the Qtrac as did 95% of full size Jeeps with the TH400.
You're preachin' to the choir in regard to AMC using leftover parts, but by the mid-70s all of the TH400s had the AMC pattern.
CSP is offline
post #15 of 17 Old 04-03-2010, 04:14 PM Thread Starter
CherryCj7
1979 CJ7
Alright, I have been looking at nokak's website and it does not have the AMC Th400 to GM engine adapter. They dont have the TH400 with the AMC pattern transmission on the site at all that i can tell. All they have are the chevy TH400 transmissions. Do they have this adapter (GM engine to AMC TH400) and i just do not see it? Any help would be great. Thanks - Vince
TH400 transmission TROUBLESHOOTING PacNW_87 Jeep CJ Forum 3 12-26-2010 07:35 PM
Bolt holding transmission in place???? TophCasey Jeep CJ Forum 10 10-19-2009 08:16 PM
will a np435 from a 91 ram150 bolt directly to 98 ram1500 318 spcmac249 Jeep CJ Forum 0 07-31-2009 12:40 PM
TH400 Transmission Lines 82cj7401 Jeep CJ Forum 2 11-28-2008 07:07 PM
Bolt Specs for T176 Transmission to Bellhousing Full Tank Jeep CJ Forum 1 09-05-2008 05:27 PM
