What engine is this? ('79?) - JeepForum.com
post #1 of 7 Old 08-29-2011, 08:40 AM Thread Starter
Bartleby_91YJ
Hi all, my girlfriend is buying her first Jeep today and I was wondering what engine it's hauling? I'm trying to figure out if it's a 3.8L or 4.2L. Also, what is that silver thing at the top? Sorry I do not know much about engines yet and I'm also a YJ guy. If I recall correctly, it's a '78 CJ.
Thanks,
YJ owner
Bartleby_91YJ is offline
post #2 of 7 Old 08-29-2011, 08:44 AM
kickingprop
silver thing should be the PCV/crankcase breather and that looks to be the good ol 4.2L 258
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #3 of 7 Old 08-29-2011, 09:44 AM
james04si
james04si's Avatar
1977 CJ5
If it is the original engine it should be the 4.2, that being said if it has been swapped the only way to tell is by the casting numbers or the engine id tag. The 232(3.8) and the 258(4.2) have identical bore but a different stroke so they look the same from the outside.
james04si is offline
post #4 of 7 Old 08-29-2011, 11:05 AM
CSP
The 232 (3.8) was available in '78, so don't assume it's a 258 (4.2).
It's a series of letters stamped into a machined surface near the distributor that determines externally what the engine is, not casting numbers or an ID tag.
CSP is offline
post #5 of 7 Old 08-29-2011, 01:08 PM
kickingprop
Learn something new everyday! I thought they phased them out in 76...
1985 CJ7 Project
post #6 of 7 Old 08-29-2011, 01:40 PM
james04si
james04si's Avatar
1977 CJ5
See and I thought it was in 77 since I was told it was even rare for mine to have come with a 232. And the stamped numbers and letters is what I meant for is tag, but I do believe you can also identify the difference by the casting numbers on the drivers side, that's how I originally identified mine as a 232.
post #7 of 7 Old 08-29-2011, 06:09 PM Thread Starter
Bartleby_91YJ
Mystery solved: It's actually a '77 with a 4.2L!
Thanks for the replies, guys!
cj5 , engine
Installed Poly engine mounts, engine won't run Beer man Jeep CJ Forum 12 08-20-2010 11:14 AM
Engine swap or engine and transmission swap Notplayn Jeep CJ Forum 3 07-13-2008 07:31 PM
How to Hook the Engine to an Engine Hoist Hybrid Jeep Jeep CJ Forum 7 02-10-2008 01:21 PM
Rebuilt engine is sucking air into engine other than through the carb cj7_79 Jeep CJ Forum 4 12-11-2005 07:32 PM
How much for New Engine? HELP! calikidbrian Jeep CJ Forum 3 08-05-2003 07:56 PM
